Lpc2000
Re: Free LPC2000 Boot Loader
2006-05-01 by jayasooriah
Hello,
If would like to know if people here would be interested in a free LPC
boot loader with the following properties:
*  autobaud on receiving a single space character;
*  Intel-hex download and run from on-chip RAM;
*  Intel-hex download to non-boot sector flash;
*  CRP feature to extent supported by hardware; and
*  kernel and compatible mode flash support.
Kernel and compatible mode flash libraries will allow existing
programs that use IAP calls to work as-is.  The CPU clock paramter
will be now be reduntant if you chose this option.
It will allow boot loader intercept method to be customised.  You can
either use P0.14 or UART method to invoke the boot loader.
It will also allow external bus interface (on parts with external bus)
to be customised at the boot loader block itself.
The aim here is to release P0.15 (and BOOT1:0) pins for general
purpose IO.
CRP equivalent will be implemented as "one time fuse" in the boot
loader itself.  Once activated, boot loader will not do anything other
than to allow the entire device to be "restored".
Restoration will be done by first erasing all sectors except boot
sector and then verifying that they are fully erased before finally
self reinitialising the boot sector itself.
The aim is to reduce CRP attack surface area of the boot loader.
The boot loader image (in hex format) can be a property of the LPC2000
forum and be freely available to any member of the forum.
I can provide Windows I86 binaries of tools to backup the supplied
boot loader on your part, to install the free boot loader, and to
revert to the boot loader that you have backed up should this be
necessary.  These tools will also be owned by the LPC2000 forum.
Boot loader will not be open soruce for legal reasons.  (Philips can
remove this restriction.)
I can also provide components of the source code relating to any tools
I provide so that co-developers on other platforms can build binaries
and distribute these freely.
My reason for doing this is to demonstrate to this forum by way of
example how one could better support the LPC Family.
If there is interest, please follow up in this thread.
Jaya
2006-05-01 by unity0724
Umm.....Some questions, don't mind:
- How do I know there is no Trojan Horse inside??
- How do I know your code does not over-cooked my flash??
  or make it raw/medium when I actually ordered well done??
- How do I know your code could handle Exception Interrupt
  properly?? without crashing??
- How do I know your code does not have CSI bugs??
- How do I know if you could understand the watchdog hardware
  in detail and handle it properly upon a watchdog reset event??
- How do I know if I will not have CRP problem, after installing
  your that boot loader?? And What's that "CRP feature to extent
  supported by hardware"??
- How do I know if you are able to get Philips to ship with your
  bootloader?? Or I need to re-load everychip? Or you could
  provide free bootloader upgrade every chip programming
  services??
- How do I know if you are Philips Certified/Appointed consultant??
Thanks!!
--- In lpc2000@yahoogroups.com, "jayasooriah" <jayasooriah@...>
wrote:
> Hello,
LPC
can
bus)
> purpose IO.
other
LPC2000
can
tools
binaries
> Regards,
> Jaya
If you get Philips to agree to disclosure of the full source, you
inspect and validate the source code yourself.
You can also use reverse engieering methods I explain here:
  http://www.cse.unsw.edu.au/~jayas/esdk/lpc2/boot-loader.html
I use the exact the same timing parameters that is boot loader uses
and in your part.  The only thing I do differently is rather than
blindly wait for a given number of cycles (and hope the flash is
ready) I poll the flash status registers to determine when it is ready.
Check out exception handling in SILL at
  http://www.cse.unsw.edu.au/~jayas/esdk/sill.html
It does not have a CSI so it cannot have CSI bugs.
See discussions in other threads here.
See the specifications of how the chip is restored.
>   services??
You do not get this boot loader from Philips.  You fetch the image and
tools from the forum download area.
You do not *have* to use this boot loader if you do not need it.
Note:
1/  Philips *cannot* forbid you from runing your own code in the boot
sector.  (Different story if boot sector is in ROM).
2/  If you are concerned about warranty issues, make a backup of hte
original boot loader in your part, and just restore it before you
raise any warranty issues with Philips.
If you want Philips Certified/Appointed cosultant, you are better of
sticking to suppied boot loader.
2006-05-01 by brendanmurphy37
>   services??
> Thanks!!
To add to the list:
- why should I break the most basic rule of design and rely on
something that in turn relies on undocumented and unsupported
features from a manufacturer?
- what do I do when I'm in production and Philips supply a batch of
parts that have some change in them that renders your boot-loader or
some feature of it ineffective?
I assume that one of the reasons for Philips implementing the boot-
loader the way it is is that it gives them the flexibility to change
the hardware without changing the documented interface to it.
Brendan
--- In lpc2000@yahoogroups.com, "brendanmurphy37"
Stick to the boot supplied boot loader if you only wish to rely on
what Philips publishes.
As for support, I do not want engage in politics.
Stick to the original boot loaeder then.  My tools have never replaced
any code without first checking what was there in the first place.
There you go making assumptions.  I do not want to go into this again.
I asked for expression of interest.  If you are not interested perhaps
you are better off staying out of this thread.
Jaya
perhaps
You're right, and I will.
My reason for the post was to point out to others the problems
associated with using undocumented and unsupported features. My
recommendation would be for anyone producing commercial products not
to do this, for the reasons I gave (amongst others).
Brendan
Re: [lpc2000] Re: Free LPC2000 Boot Loader
2006-05-01 by Micron Engineering
jayasooriah ha scritto:
I am interested only if it will be in source code form.
> Hello,
> purpose IO.
> Regards,
> Jaya
Checked by AVG Free Edition.
Version: 7.1.385 / Virus Database: 268.5.1/326 - Release Date: 27/04/2006
I like to but open source approach could potentially infringe on
Philips's rights to keeping chip initialisation methods a secret.
Suggestions anyone?
Jaya
2006-05-01 by Martin Maurer
> From: "jayasooriah" <jayasooriah@...>
> Suggestions anyone?
Ask Philips ? I think they are reading the mailinglist, perhaps they can
clarify it...
       Martin
Hi Martin,
I am quite sure Philips monitors this forum.  I am prepared to let
Philips validate my source code before it is put in public domain.
I believe Philips would respond if there is sufficient interest for
such a boot loader.
Jaya
> > Suggestions anyone?
can
> clarify it...
> Regards,
>        Martin
