Timer on LPC2138
2006-05-01 by sherifkamelzaki
hi i have a very dump question y do we use prescale while we can enter any value we want in the TOMR0
2006-05-01 by Danish Ali
Hi. There's no such thing as a dumb question. There are lazy questions (where the answer is obvious when you read the user manual). There are dumb answers. Why might you use the prescaler? It is only a 32-bit counter. So at 60 MHz, it will overflow at 2^32/60000000 = 71 seconds (I think). What happens if you want a time longer than that? The faster things run, the more power they use. So for the most power-efficient applications, you might choose to slow things down as much as possible. For this particular case it is a weak argument, but other peripherals are more power-hungry and so you can save some power this way. Philips also say that you can divide PCLK to a slower rate than core in case some of their peripherals cannot run as fast as the arm core. The also say that all current peripherals can run at 60 MHz so there is little cause to do this right now. But in future? Maybe you have a system that runs in two modes, with the processor fast or slow depending (say) whether you're running off mains or battery. If you can re-program the peripherals so they always run at the same pace (even though the arm core is different) then you don't need to recalculate all the timings etc. There's no killer reason. But one of my timers happens to have the prescaler divide by 60 so I have a 1MHz tick. It makes my calculations easier. Hope this helps, Danish --- In lpc2000@yahoogroups.com, "sherifkamelzaki" <sherifkamelzaki@...> wrote:
> > hi i have a very dump question y do we use prescale while we can enter > any value we want in the TOMR0 >
