Lpc2000
OFFTOPIC: PCB impedance calculation without GND plane
2006-05-03 by Guillermo Prandi
Hi. Sorry for the offtopic, guys. If anybody can point me out some good
forum/group to post this question, I'll be glad.
I need to calculate trace witdh and cleareance to achive an impedance
of nearly 50 ohm for an RF trace surrounded by a GND polygon. My board
is SINGLE layered, so I have no power or GND planes. There's plenty of
online calculators for this *if* I have a GND plane, but I couldn't
find any for surface impedance calculation (i.e., between tracks). Any
hints?
Guille
Re: OFFTOPIC: PCB impedance calculation without GND plane
--- In lpc2000@yahoogroups.com, "Guillermo Prandi"
good
board
of
Any
> hints?
> Guille
Oh, never mind. The price difference between single and double layer is
minimal.
Thanks anyway.
Guille
Re: [lpc2000] OFFTOPIC: PCB impedance calculation without GND plane
2006-05-03 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Wednesday, May 03, 2006 12:50 PM
Subject: [lpc2000] OFFTOPIC: PCB impedance calculation without GND plane
> hints?
You will find it impossible to get a 50 ohm impedance the way you describe.
Why not just put some copper pour on the other side of the track, making it
a microstrip section. A track width of 0.1" will give you about 50 ohms with
FR4 material. If you are stuck with a single-sided board you could glue a
piece of copper foil to the other side of the board or use some 50 ohm coax
cable. If the connection is short and the frequency not all that high, I
wouldn't bother with impedance matching anyway.
Leon
Leon Heller, G1HSM
leon.heller@...
http://www.geocities.com/leon_heller
Leon
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
--- In lpc2000@yahoogroups.com, "Leon Heller" <leon.heller@...> wrote:
> From: "Guillermo Prandi" <yahoo.messenger@...>
plane
some good
impedance
board
plenty of
couldn't
tracks). Any
> > hints?
describe.
making it
ohms with
glue a
ohm coax
high, I
> Leon
> Leon Heller, G1HSM
> leon.heller@...
> Leon
responsibility
are
Thanks, Leon. I'll keep in mind your suggestions if I bump into this
problem again, but you're right, a second layer is way easier. The
line is relatively short (1 inch), but frequency is GSM (1.8/1.9
GHz), so I want to be careful to keep signal integrity in good shape
as much as I can within reason.
Guille
Re: [lpc2000] Re: OFFTOPIC: PCB impedance calculation without GND plane
Sent: Wednesday, May 03, 2006 2:34 PM
Subject: [lpc2000] Re: OFFTOPIC: PCB impedance calculation without GND plane
>> ----- Original Message -----
> plane
> some good
> impedance
> board
> plenty of
> couldn't
> tracks). Any
>> > hints?
> describe.
> making it
> ohms with
> glue a
> ohm coax
> high, I
>> Leon
>> Leon Heller, G1HSM
>> leon.heller@...
>> Leon
> responsibility
> are
Yes, for GSM you do need to take some care with the track. I'm using a
Siemens MC55 module which has a tiny Hirose coax socket (about 2.5 mm wide)
for the antenna as well as an optional pad for connection to a PCB. I'm
using the former as it makes things easier, although I had to buy an SMA
adapter cable. I'm actually using a home-made single-sided PCB with it.
2006-05-04 by Tom Walsh
>good
>board
Since RF is RF and not digital or analog, you may want to ask around
some of the lists which deal with RF.  For example, Ham Radio (Amateur
Radio).  I have an old copy of the: G.R. Jessop,G6JP "VHF UHF Manual",
ISBN #0-900612-92-4
Jessop goes into a lot of detail about microwave and one section of the
book deals with microstripline transmission circuits.  Both using double
clad PCB as well as transmission line charactoristics of various types
of materials: slab lines (PCB traces), parallel wires, wire parallel to
infinite plane, wire in rectangular trough, etc.
For slablines:
=============== begin formula ======================
Where B is the overall length of the two parallel slabs, and, A ==
inside distance between the slabs:
Zo ~= 377 * (A / B)
(IOW Zout is approximately equal to 377 times A / B).
And, given that A << B then "edge effects are neglected"
================== snip =====================
That example is for two slablines in freespace.  However, depending on
the cross-sectional area of the slabs, I would suspect that the effect
of the PCB surface would be negligable.
If you present the line with a known impedance, design the slab line for
that impedance and terminate in the same impredance, then you do not
have to worry about 1/4 wavelength effects.  Radically change any of the
three impedances and the wavelength of the line becomes a factor.
My copy is rather dated, 1991, but it is an excellent reference.
TomW
2006-05-04 by Bisser Gatchev
Hi Guillermo. Have you tried AppCAD? It's a free download from the Agilent website.
Guillermo Prandi <yahoo.messenger@...> wrote:  Hi. Sorry for the offtopic, guys. If anybody can point me out some good
hints?
Guille
  SPONSORED LINKS
        Microcontrollers   Microprocessor   Intel microprocessors
  YAHOO! GROUPS LINKS
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
2006-05-09 by Guillermo Prandi
Thanks, Tom!
some
> >good
impedance
> >board
plenty
around
(Amateur
Manual",
> ISBN #0-900612-92-4
double
types
parallel to
> For slablines:
> Zo ~= 377 * (A / B)
on
effect
line for
not
of the
> Regards,
> TomW
Thanks, Bisser. I didn't know this program. Now I added it to
my 'useful tools' folder!
Guille
Agilent website.
impedance
board
of
Any
> hints?
> Guille
>   SPONSORED LINKS
>   YAHOO! GROUPS LINKS
Service.
and save big.
2006-05-09 by Mike
> Thanks, Tom!
A general rule of thumb with RF circuits is that traces which are less
than 1/10th of the wavelength of the highest frequency involved have a
negligible effect.
I wouldn't like to run an unshielded RF signal next to any sort of
high speed digital device though.
Mike
2006-05-09 by Tom Walsh
>>Thanks, Tom!
>negligible effect.
Good point, thanks!
TomW
