Lpc2000
IRQ handlers
IRQ handlers
2006-05-04 by jk jlkj
Hi Friends,
  I wanted to know how to write code, which will cause a jump to a interrupt handler routine when any interrupt is generated.
  The code given in the IAR manual is
  I donot understand how a function can be passed to a parameter
  "unsigned int    function" in the function declaration given below.
  unsigned int
  install_handler(unsigned int *vector, unsigned int function)
  unsigned int vec, old_vec;
  I cannot understand the below statement.
  vec = ((function - (unsigned int)vector - 8) >> 2);
  old_vec = *vector;
  vec |= 0xea000000; /* add opcode for B instruction */
  *vector = vec;
  I cannot understand the below 2 statement's.
  old_vec &= ~0xea000000;
  old_vec = ( old_vec << 2 ) + (unsigned int)vector + 8;
  return(old_vec);
  Is the above code efficient or is there a better or simpler way of doing this.
  Jerome
 Yahoo! India Answers: Share what you know. Learn something new. Click here
