Lpc2000
SPI Problem - CPHA configuration
2006-05-06 by rod_linares
Hi all,
Im building a project with an LPC2106 (master) connected with 3 SPI
slaves devices,  two with CPOL =0 , CPHA =0 and another device with
CPOL=0 ,CPHA=1.
First of all I configured the two devices with CPOL =0 , CPHA =0 and
I didn't had problems. But when i tried to include to the system the
device with CPOL=0 ,CPHA=1 the problems began to apear.
After some debugging i conclude the problem apears when I configure
the CPHA "dinamicaly" in teh code .
With the same code I initialized (and never change) the CPHA=0 and
the 2 devices (CPOL =0 , CPHA =0)  worked  ok. After that I
initialized (and never change) the CPHA=1 and the device (CPOL =0 ,
CPHA =1) and worked OK.
Finnaly , When I changed dinamicaly the CPHA in the code and I
conected the three devices  only he "CPHA=1" decvice worked OK.
This sound familiar?
any had the same problem?
Thanks in advance
Rodrigo
Re: [lpc2000] SPI Problem - CPHA configuration
2006-05-06 by Tom Walsh
rod_linares wrote:
>Hi all,
>CPOL=0 ,CPHA=1.
I will be facing a similar situation: ENC28J60 clocks on rising edge and
SD card clocking on falling edge.  So, your post is timely for me.  I
wonder if you might try a dummy SPI cycle after you switch the clock
configuration?  Don't select anything, just spit a byte out?
TomW
Re: SPI Problem - CPHA configuration
2006-05-07 by rod_linares
The problem was the "NIGHT PROGRAMMING SINDROM"
I recheck the code today in the morning and I find an bug.
So, There is no problem in dininamicaly change the CPHA values.
Rodrigo
