Lpc2000
LPC2200 Application Note on SPI (AN10369)
Re: [lpc2000] LPC2200 Application Note on SPI (AN10369)
2006-05-11 by Marko Pavlin (home)
wickedmonster2002 wrote:
> I am confused. What does #define SPIF (1<<7) mean? Everything else I
> understand.
1<<7 means 1 binary shifted left 7 places (bits). The result is 0x80 or
8'th bit set to 1. It is equal to:
#define SPIF 0x80
RE: [lpc2000] LPC2200 Application Note on SPI (AN10369)
2006-05-11 by Andrew Berney
It creates a pre-processor definition (#define) such that where ever SPIF is
used in the code it compiles it as though it was: (1<<7).
Or if you mean what does 1<<7 do? Then the << is a bitwise operator in C
that shifts the value (in this case 0x01) 7 places to the left becomes 0x80.
Get yourself a decent book on C, there's plenty out there...
Andy
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com]On Behalf
Of wickedmonster2002
Sent: 11 May 2006 15:42
To: lpc2000@yahoogroups.com
Subject: [lpc2000] LPC2200 Application Note on SPI (AN10369)
understand.
Yahoo! Groups Links
2006-05-11 by Tom Walsh
What is 2 raised to the 7th power?  This is a C statement to shift a
value of "1" left by "7" bit positions.
Simply write a binary "1" followed by 7 "0"s.  Then convert the binary
number into your favorite number base: octal, hex or decimal.
Next, use your calculator to raise 2 to the 7th  power.  See the
relationships?
TomW
Re: LPC2200 Application Note on SPI (AN10369)
2006-05-11 by brendanmurphy37
> understand.
As others have pointed out discovering **what** it means is very
simple: it's just standard 'C'.
What's less obvious is **why** this construct is used. I believe the
following is the main reason:
In many peripheral register descriptions, you will see the function of
individual bits described. This is the case for "SPIF", which is bit 7
in SPSR. Rather than work out by hand (and perhaps getting it wrong),
the simplest thing is to get the pre-processor to do it for you. In the
general case:
#define BIT_NAME (1 << bit_position)
That way it's easy to cross check the definition in the code against
the documentation.
You can then use it in code to select the bit of interest as follows:
if (S0SPSR & SPIF)
  do_something();
Brendan
2006-05-11 by wickedmonster2002
Thanks guys for all the variable answers. I am pro in Assembly
programming. I m just getting into C. I was used to C++ before, but
that was before I got into Embedded systems.
> understand.
Re: [lpc2000] Re: LPC2200 Application Note on SPI (AN10369)
2006-05-12 by jk jlkj
Hey Karim are u into weighing scales by any chance.
wickedmonster2002 <karim@...> wrote:  Thanks guys for all the variable answers. I am pro in Assembly
> understand.
  SPONSORED LINKS
        Microcontrollers   Microprocessor   Intel microprocessors
  YAHOO! GROUPS LINKS
Yahoo! India Answers: Share what you know. Learn something new. Click here
Send instant messages to your online friends - NOW
2006-05-12 by wickedmonster2002
Yes I am...I just got into it a month and half ago. Excellent Educated
Guess by the way.
> > understand.
>   SPONSORED LINKS
>   YAHOO! GROUPS LINKS
Service.
Click here
2006-05-13 by jk jlkj
where r u working from, ru in the US.
wickedmonster2002 <karim@...> wrote:  Yes I am...I just got into it a month and half ago. Excellent Educated
Guess by the way.
> > understand.
>   SPONSORED LINKS
>   YAHOO! GROUPS LINKS
Service.
Click here
  SPONSORED LINKS
  YAHOO! GROUPS LINKS
 What makes Sachin India's highest paid sports celebrity?, Share your knowledge on Yahoo! India Answers
