Lpc2000
Who have ZLG EasyARM 2200's source code?
2006-05-15 by xiao hu
I need ZLG EasyARM 2200's source code.Could you send
it to me?
___________________________________________________________
\ufffd\ufffd\u05e2\ufffd\u017b\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd-3.5G\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd20M\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd
http://cn.mail.yahoo.com
Re: [lpc2000] Who have ZLG EasyARM 2200's source code?
2006-05-15 by Micron Engineering
> it to me?
what is this? I found it is a LPC2106 board so it hasn,t source code.
> 抢注雅虎免费邮箱-3.5G容量,20M附件!
Checked by AVG Free Edition.
Version: 7.1.392 / Virus Database: 268.5.6/339 - Release Date: 14/05/2006
Re: Who have ZLG EasyARM 2200's source code?
2006-05-15 by EmbeddedHub
hi XiaoHu, probably, you may request for the sample codes from ZLG
directly or download the sample codes from others and modify it to
suit the board.
Tim.
http://www.embeddedhub.com/
> it to me?
> ~{G@W"QE;"Cb7QSJOd~}-3.5G~{H]A?#,~}20M~{8=<~#!~}
Re: [lpc2000] Re: Who have ZLG EasyARM 2200's source code?
EmbeddedHub \u5199\u9053:
codes from ZLG
and modify it to
> suit the board.
> Regards,
> Tim.
> --- In lpc2000@yahoogroups.com, xiao hu
send
> > it to me?
> SPONSORED LINKS
> Microcontrollers
<http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel
microprocessors&c=3&s=69&.sig=c-HXthtbZy4TZbI3ib0PMg>
> 	Microprocessor
<http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel
microprocessors&c=3&s=69&.sig=ijt0SspWtjogcHCuFD0lUQ>
> 	Intel microprocessors
> <http://groups.yahoo.com/gads?t=ms&k=Intel
microprocessors&w1=Microcontrollers&w2=Microprocessor&w3=Intel
microprocessors&c=3&s=69&.sig=WOZdpklkgHbXR5quAgrl5w>
> YAHOO! GROUPS LINKS
>     * Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on
the web.
>     * To unsubscribe from this group, send an email
to:
>       lpc2000-unsubscribe@yahoogroups.com
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     * Your use of Yahoo! Groups is subject to the
Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
Thanks! But i have not the sample coeds. Who can send
it to me ?
DSPINXD
DSPINXD@...
XIDIAN UNIVERSITY
No.2 SOUTH TaiBai ROAD XI'AN,Shaanxi,710071,P.R.CHINA
\ufffd\u03ff\ufffd\u05e2\ufffd\ufffd\ufffd\u017b\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd\ufffd?
Micron Engineering \u0434\ufffd\ufffd:
send
> > it to me?
hasn,t source code.
<ttp://cn.mail.yahoo.com%22>
> > Yahoo! Groups Links
removed]
> SPONSORED LINKS
> Microcontrollers
<ttp://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel
microprocessors&c=3&si&.sig=c-HXthtbZy4TZbI3ib0PMg%22>
> 	Microprocessor
<ttp://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel
microprocessors&c=3&si&.sig=ijt0SspWtjogcHCuFD0lUQ%22>
> <ttp://groups.yahoo.com/gads?t=ms&k=Intel
microprocessors&c=3&si&.sig=WOZdpklkgHbXR5quAgrl5w%22>
> YAHOO! GROUPS LINKS
the web.
to:
Yahoo! Terms of
It is a chinese company's products with LPC2210.
If your have some lpc2XXX code about modem
comunicatio,send it to me,Thanks!
DSPINXD
DSPINXD@...
XIDIAN UNIVERSITY
http://cn.mail.yahoo.com/
xiao hu ha scritto:
english please
> Micron Engineering 写道:
> send
>>> it to me?
> hasn,t source code.
>>> Yahoo! Groups Links
> removed]
>> SPONSORED LINKS
>> Microcontrollers
>> 	Microprocessor
>> YAHOO! GROUPS LINKS
> the web.
> to:
> Yahoo! Terms of
What?
what's the meaning?
DSPINXD
DSPINXD@...
XIDIAN UNIVERSITY
erase flash memory thru command prompt
2006-05-15 by richa gupta
For erasing the contents of flash memory from the command prompt  this is the syntax but what will be value of result
  unsigned long command[5];
  unsigned long result[2];
  or
  unsigned long * command;
  unsigned long * result;
  command=(unsigned long *) 0x…..
  result= (unsigned long *) 0x…..
  Define pointer to function type, which takes two parameters and returns void. Note the IAP returns the result with the base address of the table
  residing in R1.
  typedef void (*IAP)(unsigned int [],unsigned int[]);
  IAP iap_entry;
  Setting function pointer
  iap_entry=(IAP) IAP_LOCATION;
  Whenever user wishes to call IAP within the application, the following statement could be used.
  iap_entry (command, result);
  what will be the value of result
  thanks in advance
  Richa
Yahoo! Mail goes everywhere you do.  Get it on your phone.
xiao hu ha scritto:
> What?
> what's the meaning?
I received an answer with some chinese (I suppose) that I am not able to
understand
2006-05-16 by xiao hu
Micron Engineering :
> xiao hu ha scritto:
> > What?
> > what's the meaning?
> understand
removed]
> SPONSORED LINKS
> Microcontrollers
> 	Microprocessor
> YAHOO! GROUPS LINKS
the web.
to:
Yahoo! Terms of
I see.It's not important. Xiedao(\u5199\u5230) means written
by.
I need some code about LPC2000 and modem.Could you
help me?
Thanks!
DSPINXD
DSPINXD@...
XIDIAN UNIVERSITY
Micron Engineering :xiao hu hascritto:
> What?
> what's the meaning?
understand
Version: 7.1.392 / Virus Database: 268.5.6/339 - Release Date:14/05/2006
    SPONSORED LINKS
                     icrocontrollers                 Microprocessor                 Intelmicroprocessors
  YAHOO! GROUPS LINKS
    To unsubscribe from this group, send anemail to:
I see.It's not important. Xiedao(\u5199\u5230) means written by.
I need some code about LPC2000 and modem.Could you help me?
Thanks!
-- DSPINXDDSPINXD@... UNIVERSITYNo.2 SOUTH TaiBai ROAD XI'AN,Shaanxi,710071,P.R.CHINA
 雅虎免费邮箱-3.5G容量,20M附件
2006-05-16 by Dezheng Tang
Goto "Files" area on the left side. There are many S/W examples,
one of them is posted by "Philips Apps".
> > xiao hu ha scritto:
> > > What?
> > > what's the meaning?
> > understand
> removed]
> > SPONSORED LINKS
> > Microcontrollers
l
> > 	Microprocessor
> > YAHOO! GROUPS LINKS
> the web.
> to:
> Yahoo! Terms of
> I see.It's not important. Xiedao(写到) means written
> by.
> help me?
> Thanks!
> DSPINXD
> DSPINXD@...
> XIDIAN UNIVERSITY
> ÇÀ×¢ÑÅ»¢Ãâ·ÑÓÊÏä-3.5GÈÝÁ¿£¬20M¸½¼þ£¡
RE: [lpc2000] erase flash memory thru command prompt
2006-05-17 by Pandurang Shinde
hi,
        when you invoke iap routine with command in command array , result array contain the status(result) of the operation.
Return Code may be
CMD_SUCCESS |
COMPARE_ERROR |
COUNT_ERROR (Byte count is not a multiple of 4) |
ADDR_ERROR |
ADDR_NOT_MAPPED
0 - CMD_SUCCESS Command is executed successfully.
1 - INVALID_COMMAND Invalid command.
2 - SRC_ADDR_ERROR Source address is not on a word boundary.
3 - DST_ADDR_ERROR Destination address is not on a correct boundary.
4  -SRC_ADDR_NOT_MAPPED Source address is not mapped in the memory map.
u can get this inforamtion in flash memory system & programming section.
I hope it is what u expected.
Pandurang S.
From: lpc2000@yahoogroups.com on behalf of richa gupta
Sent: Mon 5/15/2006 9:46 PM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] erase flash memory thru command prompt
  or
  command=(unsigned long *) 0x.....
  result= (unsigned long *) 0x.....
  residing in R1.
  IAP iap_entry;
  thanks in advance
  Richa
SPONSORED LINKS
Microcontrollers <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=c-HXthtbZy4TZbI3ib0PMg>  	Microprocessor <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=ijt0SspWtjogcHCuFD0lUQ>  	Intel microprocessors <http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=WOZdpklkgHbXR5quAgrl5w>
YAHOO! GROUPS LINKS
*	 Visit your group "lpc2000 <http://groups.yahoo.com/group/lpc2000> " on the web.
*	 To unsubscribe from this group, send an email to:
	 lpc2000-unsubscribe@yahoogroups.com <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
