Lpc2000
error for RDI in keil "MISSING DEVICE (R003:SECURITY KEY NOT FOUND)"
2006-05-26 by naderus2000
hi,
i configure keil for working with RDI for
wiggler jtag but when want to start debug
a massege box apear that write:
 Running in eval Mode.
and then download the code but the code doesn't run.
please tell me what should i do?
thanks a lot.
Re: error for RDI in keil "MISSING DEVICE (R003:SECURITY KEY NOT FOUND)"
2006-05-26 by Sutton Mehaffey
That message is no big deal.  You are just running the evaluation
version of the software and that's the message you get sometimes.  It
will go away once you purchase the full-blown version.
--- In lpc2000@yahoogroups.com, "naderus2000" <naderus2000@...> wrote:
> hi,
> thanks a lot.
Re: [lpc2000] Re: error for RDI in keil "MISSING DEVICE (R003:SECURITY KEY NOT FOUND)"
2006-05-27 by nader chinichian
my code is about 10k not above 16k so the complier must work.
  if i use in GNU complier is it work?
> hi,
> thanks a lot.
  SPONSORED LINKS
        Microcontrollers   Microprocessor   Intel microprocessors
  YAHOO! GROUPS LINKS
Do you Yahoo!?
 Get on board. You're invited to try the new Yahoo! Mail Beta.
2006-05-27 by Danish Ali
You have two totally separate issues:
One message asking you to pay for a commercial license.
The other that your code does not run.
These are unrelated.
Why doesn't your code run? There are many possible problems. Try one of the standard
Keil demos. You'll still get the message. But the code should run.
Using the GNU compiler is not a full solution, because (in my opinion) a major reason to
use Keil is its debugger, which works very well with the on-board peripherals in the
LPC2000 chips. As far as I know, the debugger is also code-size-restricted.
Hope this helps,
Danish
> --- In lpc2000@yahoogroups.com, "naderus2000" <naderus2000@> wrote:
> > hi,
> > thanks a lot.
2006-05-28 by nader chinichian
hi
  i write simple serial test in keil.
after start debugger it get in to the buger menu but nothing happend.
beacuse it write a simple led flasher in iar and it work and the flashing of
led never stop.
also in the flash menu i use erase icon but nothing get happend only the
flashing led stop and after reset it again start.
  what should i do to erase or download my code?
Hope this helps,
Danish
> > hi,
> > thanks a lot.
  SPONSORED LINKS
  YAHOO! GROUPS LINKS
Be a chatter box. Enjoy free PC-to-PC calls  with Yahoo! Messenger with Voice.
2006-05-29 by applehuu
    Because:
    http://www.keil.com/support/man/docs/license/license_errors.htm
    Security Key Messages
      R003: SECURITY KEY NOT FOUND
      Your license is protected by a security key, but the security key
      is not found on your computer. Refer to *GENERAL: UPGRADED TO
      WINDOWS NT/2000 AND PROTECTION FAILS*
      <http://www.keil.com/support/docs/128.htm> in the support
      knowledgebase for more information. It is recommended that you use
      the *Dongle Testing Application* that may be downloaded from this
      article.
On 2006-5-29 2:54, nader chinichian wrote:
> hi
> flashing of
> led never stop.
> of the standard
> a major reason to
> peripherals in the
> Hope this helps,
> Danish
> > > hi,
> > > thanks a lot.
>   SPONSORED LINKS
>   YAHOO! GROUPS LINKS
> with Voice.
> SPONSORED LINKS
> Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=c-HXthtbZy4TZbI3ib0PMg>
> 	Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=ijt0SspWtjogcHCuFD0lUQ>
> <http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=WOZdpklkgHbXR5quAgrl5w>
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
2006-05-31 by nader chinichian
hi,
  Now i'm trying to debug my code with wiggler in keil but get this massege now:
  Load "C:\\Documents and Settings\\....\\Obj_KEIL\\BasicSAM7_KEIL.ELF"
_____^
*** error 56: cant open file
  can some one please tell me how can i solve this?
thanks.
> hi,
> thanks a lot.
  SPONSORED LINKS
  YAHOO! GROUPS LINKS
Do You Yahoo!?
http://mail.yahoo.com
