indirect cs3 address
2006-05-31 by mayotte_d
I am trying to get my LPC2292 to use indirect memory addressing on the address bus with cs3. It seems ok on the scope but to acutally use it I have to be able to use the base address and add to it. If I use: (REGISTER_OFFSET) = 0x00000055; //test cs3 the address 80000000 gets the 55 but what I want to do is (REGISTER_OFFSET + 3) = 0x00000055; //test cs3 which I thought was the same thing except 3 addresses up. This always generates an IAR compiler error. "(Error[Pe137]: expression must be a modifiable lvalue" If I try to convert the REGISTER_OFFSET to a pointer in memory it wont let me establish a pointer. I tried "unsigned long * ptr1; "and the same with * char, and others but its a no-go. So if anyone would be so kind as to tell me how to solve this, then at least one person in the world is happy.
