Lpc2000
IAP erase
IAP erase
2006-06-01 by lpc.lover
Hi all.
I write this code for erase flash of a LPC2106.
This code is base on some code I found on Internet.
I when to know what is a SectorStar? that resembles to?
Flash sector prepare give me a result of 7. What that mean?
Thank.
int EraseSectors(unsigned int SectorStart, unsigned int SectorEnd,
unsigned long ProcFrequency)
   unsigned long command[5];
   unsigned long result[2];
   IAP iap_entry = (IAP) IAP_LOCATION;
  __disable_interrupt();
  command[0] = FLASH_PREPARE_SECTOR_TO_WRITE;
  command[1] = SectorStart;
  command[2] = SectorEnd;
  command[3] = ProcFrequency;
  iap_entry(command, result);
// result[0] always give me 7!!! I don't know what is this error.
  if (CMD_SUCCESS == *result) {
    command[0] = FLASH_ERASE_SECTORS;
  __enable_interrupt();
   return (CMD_SUCCESS == *result);
Re : [lpc2000] IAP erase
2006-06-01 by Xedius Zolva
The error 7 is for INVALID_SECTOR
----- Message d'origine ----
De : lpc.lover <lpc.lover@...>
À : lpc2000@yahoogroups.com
Envoyé le : Jeudi, 1 Juin 2006, 11h49mn 38s
Objet : [lpc2000] IAP erase
   Hi all.
 Thank.
        SPONSORED LINKS
                                                    Microcontrollers                                       Microprocessor                                       Intel microprocessors
         YAHOO! GROUPS LINKS
Re: [lpc2000] IAP erase
2006-06-01 by Tom Walsh
lpc.lover wrote:
>Hi all.
The User Manual for the LPC2106 has a fine reference of the IAP.  Please
read it.  They even give the error codes.  Then read the section of the
manual which describes the internal Flash Memory.
The Philips documentation may be slim in some areas, but it is very good
about the Flash & IAP.
TomW
