Lpc2000
speed of pin toggle
speed of pin toggle
2004-05-05 by douglasbolton
I believe I've set the PLL of an lpc2106 with a 14.7 mhz crystal up
to be 59 Mhz
However when I toggle a GPIO pin using IOSET,IOCLR,IOSET it is only
low for approx 200 nS. I was expecting quicker than this.
Any thoughts ???
Re: [lpc2000] speed of pin toggle
2004-05-05 by the ARM Patch
Douglas
  Two things to remember.
1) It will take more than two assembly instructions to toggle
an IO line in a loop.  Take a look at the assembly code produced
by the compiler to determine the instruction count.
2) the GPIO is on the VPB (VLSI Periphereal Bus) and can only be
written at the PCLK rate.  If your PCLK divider is '1' then the
processor will not have to wait.  If not '1' then the GPIO pin
cannot be updated at the CLK (~59MHz) rate.
-Bill Knight
the ARM Patch
to be 59 Mhz
Any thoughts ???
Re: speed of pin toggle
2004-05-05 by tsvetanusunov
> to be 59 Mhz
> Any thoughts ???
where do you run your code from? RAM or Flash?
Flash can't work at 59Mhz (read the docs ;) and usually code from
Flash runs slower than from RAM - make blink LED code and compile it
for RAM and Flash - you will see visual the difference
Best regards
Tsvetan
PCB prototypes for $26 at http://run.to/pcb
(http://www.olimex.com/pcb)
PCB any volume assembly (http://www.olimex.com/pcb/protoa.html)
Development boards for ARM, AVR, PIC, and MSP430
(http://www.olimex.com/dev)
2004-05-05 by Robert Adsett
>to be 59 Mhz
>Any thoughts ???
See http://groups.yahoo.com/group/lpc2000/message/37 the thread where this
was discussed earlier.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Re: [lpc2000] Re: speed of pin toggle
2004-05-05 by MaxStream - Ryan Bedwell
True, but if you have the memory accelerator (MAM) on, this tight of a
loop should run with zero wait states from flash on the 21xx.  A loop
this small will probably fit completely in the MAM buffers.
Ryan
