Lpc2000
2 applications in flash
2004-05-07 by gnurules
I'm writing 2 applications for the LPC2106 (they run in flash).
1) is a bootcode that checks if there is another application
   in flash
2) is the "regular" application
At startup the bootcode starts and when it finds that there is
another application it should start this application.
The problem is that the interruptvectors aren't correct anymore...
Is there anyone with the same problem?
Can anyone help me with this?
Greetz
Re: [lpc2000] 2 applications in flash
2004-05-07 by Bill Knight
Have the second application remap its interrupt vectors to
RAM.
-Bill Knight
the ARM Patch
   in flash
2004-05-11 by Charles Manning
This is the model I typically use for embedded applications.
The "bootloader" is built as a regular chunk of code. THis does two things:
* Checks for a break
* Does a checksum calc on the "application area".
If there is a break or the checksum fails then the bootloader enters a state
that allows upgrading the "application area" via RS232.
If there is no break and the checksum is OK, then the "application" is
executed.
The only difference in building code for the "application area" vs the normal
build is to use a different ldscript to locate the program at the desired
offset instead of zero.
-- Charles
On Friday 07 May 2004 21:59, gnurules wrote:
> Hi,
>    in flash
> Greetz
