thanks for your reply, it work better but not
completly,
if I first start my board, load my code in
ram and execute, it don't worked.
if I load with debugger a code in ram at
start adress 0x40000000, it works
then if I reload by serial my code in
0x40000200 with the same process the first time, It works.
Why ?
Sent: Monday, May 10, 2004 9:31 PM
Subject: [lpc2000] Re: How execute ram
code after load by isp command
Sebastien,
You are overwriting the bootloader RAM
variables area.
Use 0x40000200 as start address. Also relink your code to
run from
address 0x40000200.
Philips apps.
--- In lpc2000@yahoogroups.com, Sébastien
MARION (UMM)
<s.marion@u...>
wrote:
> Hi,
> I want load a code in ram with isp
command and then execute it.
> I load the code successfull in ram (start
adresse 0x40000000) but
when I send the Go command, nothing append
> if I start my debugger and watch the memory content, the data is
correct.
> Wich caution do I take for realize this task
> Sebastien
