Good resource for FAT16?
2004-05-15 by cpexed
Hello, I am going to be trying to interface a SD MMC over the SPI interface on a LPC2106. I would like to have a FAT file sys for the mmc are there any good resources online that describe the FAT file system? Thanks Josiah
2004-05-15 by James Dabbs
If you want to solve this problem with a few dollars, Micrium's uC/FS looked like a very good solution. We haven't used it (yet), but we did license Micrium's uC/GUI for another ARM project and it worked flawlessly -- 30 minutes of work and we were up ang running. James Dabbs, TGA
2004-05-17 by Lasse Madsen
www.prllc.com Has a FAT16/FAT12 system that works ok... Regards Lasse Madsen -----Oprindelig meddelelse----- Fra: cpexed [mailto:cpexed@...] Sendt: 15. maj 2004 19:03 Til: lpc2000@yahoogroups.com Emne: [lpc2000] Good resource for FAT16? Hello, I am going to be trying to interface a SD MMC over the SPI interface on a LPC2106. I would like to have a FAT file sys for the mmc are there any good resources online that describe the FAT file system? Thanks Josiah Yahoo! Groups Links
2004-05-17 by opravar
Hello, as far as I know www.prllc.com has FAT12/16 for AVR,PIC only. We have a project which implements FAT12/FAT16 on LPC2106, later on other Philips ARM chips. Currently, we support Atmel AT45DBxxx DataFlash only, we'll add larger SD MMC later. What SD MMC support do you need specifically ? How urgent is it ? We plan to offer LPC2106 library with FAT12/FAT16 interface in august. It will be a low cost software, expect 99 EUR or so. Any ideas/feedback from your side are welcomed. Also your email address would be welcomed. Cheers Ivan --- In lpc2000@yahoogroups.com, "Lasse Madsen" <lm@h...> wrote:
> www.prllc.com > > Has a FAT16/FAT12 system that works ok... > > Regards > Lasse Madsen > > -----Oprindelig meddelelse----- > Fra: cpexed [mailto:cpexed@y...] > Sendt: 15. maj 2004 19:03 > Til: lpc2000@yahoogroups.com > Emne: [lpc2000] Good resource for FAT16? > > > Hello, > > I am going to be trying to interface a SD MMC over the SPI interface > on a LPC2106. I would like to have a FAT file sys for the mmc are > there any good resources online that describe the FAT file system? > > Thanks > > Josiah > > > > > Yahoo! Groups Links
2004-05-18 by Lasse Madsen
PRLLC's system is written in ANSI C with no AVR references so its should be about half a days work implementing it on the LPC series with a C compiler ... regards lasse madsen -----Oprindelig meddelelse----- Fra: opravar [mailto:opravar@...] Sendt: 17. maj 2004 18:25 Til: lpc2000@yahoogroups.com Emne: Re: SV: [lpc2000] Good resource for FAT16? Hello, as far as I know www.prllc.com has FAT12/16 for AVR,PIC only. We have a project which implements FAT12/FAT16 on LPC2106, later on other Philips ARM chips. Currently, we support Atmel AT45DBxxx DataFlash only, we'll add larger SD MMC later. What SD MMC support do you need specifically ? How urgent is it ? We plan to offer LPC2106 library with FAT12/FAT16 interface in august. It will be a low cost software, expect 99 EUR or so. Any ideas/feedback from your side are welcomed. Also your email address would be welcomed. Cheers Ivan --- In lpc2000@yahoogroups.com, "Lasse Madsen" <lm@h...> wrote: > www.prllc.com > > Has a FAT16/FAT12 system that works ok... > > Regards > Lasse Madsen > > -----Oprindelig meddelelse----- > Fra: cpexed [mailto:cpexed@y...] > Sendt: 15. maj 2004 19:03 > Til: lpc2000@yahoogroups.com > Emne: [lpc2000] Good resource for FAT16? > > > Hello, > > I am going to be trying to interface a SD MMC over the SPI interface > on a LPC2106. I would like to have a FAT file sys for the mmc are > there any good resources online that describe the FAT file system? > > Thanks > > Josiah > > > > > Yahoo! Groups Links Yahoo! Groups Links
