Lpc2000
PWM with olimex lpc2106-mt pcb - how to?
2004-07-20 by killtheclock
Hi all,
I have an olimex lpc2106-mt pcb and try to program a PWM without
success. The Docu is not especially detailed (I think). I tried a lot
of register settings(for hours). All I get is a single 88.64 ms pulse
on PWM4 at reset that does not change with the match register or pre-
scaler value.
This code is one example that illustrates my understanding of that
thing:
//testing PWM4
  PINSEL0 |= 0x20000;   // select pin 0.08 PWM4 function
  PWM_PR  = 0x0000;    // max prescale counter value
  PWM_MCR = 0x0002;   // reset when PWMMR0 matches
  PWM_PCR = 0x1000;   // PWM4 enable, single edge
  PWM_MR0 = 0x0f00;    // match register trigger value
  PWM_TCR = 0x0009;    // set the TC counter and enable the PWMs
I would expect a 1.92 kHz frequency from that...
Obviously I do something completly wrong.
Any help is really apreciated
Cheers, Kurt.
Re: PWM with olimex lpc2106-mt pcb - how to?
2004-07-20 by Karl Olsen
--- In lpc2000@yahoogroups.com, "killtheclock" <kurt.westphal@g...>
lot
pulse
pre-
> scaler value.
> thing:
> //testing PWM4
You also need to set PWM_MR4, and then PWM_LER before the PWM_MRx
values take effect.
Karl Olsen
2004-07-21 by killtheclock
I still can't get it running. Karl showed me the way to understand
the docu - at least I felt like understanding it...
Current code status:
//testing PWM4
  PWM_MCR = 0x0002;   	// reset TC when PWMMR0 matches
  PWM_PCR = 0x7E00;   	// enable all PWM just to get the right one
  PWM_TCR = 0x000A;	// reset TC counter (not yet needed?!)
  PWM_MR0 = 0x0400;    	// match register 0 trigger value
  PWM_LER |= BIT0;
  PWM_MR4 = 0x0150;	// match register 4 trigger value
  PWM_LER |= BIT4;
But still getting the single 88.64 ms pulse.
Any idea?
Cheers, Kurt.
> lot
> pulse
> pre-
> > scaler value.
that
> > thing:
> > //testing PWM4
> values take effect.
> Karl Olsen
Re: [lpc2000] Re: PWM with olimex lpc2106-mt pcb - how to?
2004-07-21 by microbit
> //testing PWM4
>   PWM_LER |= BIT0;
>   PWM_LER |= BIT4;
> Any idea?
> Cheers, Kurt.
Hi Kurt,
I think the main problem is that you have to wait until you get the Match _before_
the PWM cycle is actually written. This would explain why you only get a single pulse.
Follow this procedure I use :
/* Setting the PWM cycle */
PWMTCR = 0x0B;                // Hold TC in reset while altering Cycle
PWMMR0 = CYCLE;             // Write the new PWM period
PWMMCR = 0x01;               // Allow the INT flag for MR0
PWMTCR = 0x09;                // Restart PWM
PWMIR |= 0x01;                 // Reset MR0 Int flag
PWMLER = 0x01;                // Enable PWM0 latch
while ( ! (PWMIR & 0x01));  // Wait for match -> new cycle complete
PWMMCR = 0;                    // Disable MR0 Int flagging
/* Setting , for example, PWM5 */
PWMMR5 = DUTY;              // write duty cycle
PWMLER = 0x20;                // enable PWM5 Latch
Obviously CYCLE is the total PWM cycle and PERIOD makes the
PWM's dutycycle as = DUTY / CYCLE
So if you eg. set CYCLE to 1000 and DUTY to 150 you would get a 15% dutycycle
with a frequency of PCLK / 1000 (cycle), providing Prescaler is set to ONE (=0).
There might be better ways of doing this, but this way ensures you wait long enough
for the PWM period cycle to update, but no longer than necessary......
B rgds and good luck,
Kris
Strange behavior on P0.02/P0.03
2004-07-21 by Curt Powell
We're seeing some strange pin behavior between an lpc2106 (on an Olimex
H2106 board) and a USB FIFO (DLPUSB245M).  I'm wondering if anyone has
any ideas.  When running a simple loopback test sending data from lpc to
FIFO, bits 2 and 3 (on P0.02 and P0.03) do not get set to 1 but on the
next byte sent they do (if they would be 1 on that byte).
Example:  Sending a sequence of 16 bytes (values 0x00-0x0f) whenever bit
2 or 3 transitions from 0 to 1 (i.e. on 0x4, 0x8, 0xc) it is 0 but on
the next byte sent it is 1.  There is no issue with a 0 -> 1 transition.
        hex     bin    actual
Sending 0x00 00000000 00000000
Sending 0x01 00000001 00000001
Sending 0x02 00000010 00000010
Sending 0x03 00000011 00000011
Sending 0x04 00000100 00000000 <- bit 2 is 0, should be 1
Sending 0x05 00000101 00000101 <- bit 2 is 1 this time
Sending 0x06 00000110 00000110
Sending 0x07 00000111 00000111
Sending 0x08 00001000 00000000 <- bit 3 is 0, should be 1
Sending 0x09 00001001 00001001 <- bit 3 is 1 this time
Sending 0x0a 00001010 00001010
Sending 0x0b 00001011 00001011
Sending 0x0c 00001100 00001000 <- bit 2 is 0, should be 1
Sending 0x0d 00001101 00001101 <- bit 2 is 1 this time
Sending 0x0e 00001110 00001110
Sending 0x0f 00001111 00001111
This doesn't happen on any of the other 6 data pins.  We were thinking
it might have something to do with the alternate functions on
P0.02/P0.03 (I2C or timer 0) but we are not using those functions and in
fact are explicitly setting P0.02/P0.03 to GPIO at the beginning of the
program.
Any ideas?
TIA,
Curt
Re: [lpc2000] Strange behavior on P0.02/P0.03
Have you pulled those pins ?
Off-the-cuff from memory they're the I2C pins, and open drain.
From your sequence xample seems like you have moments where
the pull up fails, depending on the sequence
-- Kris
To: <lpc2000@yahoogroups.com>
Sent: Thursday, July 22, 2004 7:17 AM
Subject: [lpc2000] Strange behavior on P0.02/P0.03
>         hex     bin    actual
> program.
> Any ideas?
> TIA,
> Curt
>       Yahoo! Groups Sponsor
>             ADVERTISEMENT
>   a.. To visit your group on the web, go to:
>   http://groups.yahoo.com/group/lpc2000/
>   b.. To unsubscribe from this group, send an email to:
>   lpc2000-unsubscribe@yahoogroups.com
>   c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
RE: [lpc2000] Strange behavior on P0.02/P0.03
2004-07-22 by Curt Powell
Yup.  Since we weren't using i2c we didn't read the part that said
they're open-drain outputs.  10K pull-ups did the trick...
Sent: Wednesday, July 21, 2004 2:41 PM
To: lpc2000@yahoogroups.com
Subject: Re: [lpc2000] Strange behavior on P0.02/P0.03
-- Kris
Olimex
to
bit
transition.
>         hex     bin    actual
in
> program.
> Any ideas?
> TIA,
> Curt
>             ADVERTISEMENT
Service.
Yahoo! Groups Links
2004-07-23 by killtheclock
Now I got it:
It is really simple. The only problem was that I inited P0.8 to be
used as TxD UART 1, PINSEL P0.8 bits set to 01. Then in the main
program I set the bits to 10.
  PINSEL0 |= 0x20000;
That resulted in both bits set for P0.8, wich is undefined and does
not work.
This code does work:
        //setup PWM4
	PINSEL0 &= ~BIT16; // deselect pin 0.08 GPIO function
	PINSEL0 |= BIT17;  // select pin 0.08 PWM4 function
	PWM_PCR = BIT12;   //PWM4 enable, single edge
	PWM_MR0 = 0x400;   // MR0 must be set prior to enabling
                           // the PWM
	PWM_MCR = 0x02;	   // enable reset on MR0
	PWM_TCR = 0x09;    // PWM enable and counter start
        PWM_MR4 = 0x0200;  // match register 4 trigger value
        PWM_LER |= 0x10;   // latch MR4
Kris, there is no need to poll the interrupt flag when you init MR0
before enabling PWM mode.
The docu says (UM_LPC2106_2105_2104_1.pdf, p.152, table 117):
"Note that the PWM Match register that determines the PWM rate (PWM
Match 0) must be set up prior to the PWM being enabled. Otherwise a
Match event will not occur to cause shadow register contents to
become effective."
Thank you Kris and Karl,
regards,
Kurt.
understand
> > //testing PWM4
right one
> >   PWM_LER |= BIT0;
> >   PWM_LER |= BIT4;
PWMs
> > Any idea?
> > Cheers, Kurt.
> Hi Kurt,
Match _before_
get a single pulse.
Cycle
dutycycle
to ONE (=0).
wait long enough
necessary......
> Kris
