After some research in other samples I found a tip :
I have to change a line in the default startup.s :
.section .vectors, "ax"
.code 32
.align 0
* Exception Vectors
_vectors:
ldr pc, [pc, #reset_handler_address - . - 8] /* reset */
ldr pc, [pc, #undef_handler_address - . - 8] /* undefined instruction */
ldr pc, [pc, #swi_handler_address - . - 8] /* swi handler */
ldr pc, [pc, #pabort_handler_address - . - 8] /* abort prefetch */
ldr pc, [pc, #dabort_handler_address - . - 8] /* abort data */
.word 0xB9205F84 /* boot loader checksum */
ldr pc, [pc, #irq_handler_address - . - 8] -----------> TO LDR PC,
[PC, #-0xFF0]
ldr pc, [pc, #fiq_handler_address - . - 8]
I don't understand the mean of this modificication but it works ?
Why #-0xFF0 ?
What's that syntax : _ . - 8 ?
thanks in advance !
--- In lpc2000@yahoogroups.com, "Randy Ott" <randy@t...> wrote:Show quoted textHide quoted text
> Yann,
> Unless you supply an irq_handler, the default weak symbol will be
> linked and the interrupt will branch to an infinite loop. I use a
> handler in C that looks like this:
> __irq __arm void irq_handler(void)
> void (*interrupt_function)();
> unsigned int vector;
> vector = VICVectAddr; // Get interrupt vector.
> interrupt_function = (void(*)())vector;
> (*interrupt_function)(); // Call vectored interrupt function.
> VICVectAddr = 0; // Clear interrupt in VIC.
> I don't know how the __irq and __arm attributes are declared in
> Crossworks. If it is GNU then I believe you need to change the
> function declaration to:
> irq_handler(void) __attribute__ ((interrupt ("IRQ")))
> Hope this helps.
> Randy Ott
> --- In lpc2000@yahoogroups.com, "nourson54" <yannsuisini@h...> wrote:
> > Hi,
> > I'm trying to play with interrupts with Crossworks but I can't get
> it
> > working , even with the samples code (timer0 interrupt) .
> > I debug with Olimex JTAG .
> > I put a breakpoint on my interrupt ISR but it never breaks on it
> > but in the startup code :
> > * Default exception
> handlers
> > * These are declared weak symbols so they can be redefined in user
> > code. *
> > undef_handler:
> > b undef_handler
> > swi_handler:
> > b swi_handler
> > pabort_handler:
> > b pabort_handler
> > dabort_handler:
> > b dabort_handler
> > irq_handler:
> > b irq_handler <----------------------- BREAKS HERE
> > fiq_handler:
> > b fiq_handler
> > .weak undef_handler, swi_handler, pabort_handler, dabort_handler,
> > irq_handler, fiq_handler
> > Could someone help me ?
> > thx
> > Yann
> > PS: I'm a newbie in ARM world ;-) So excuse me if it seems a
> trivial
> > question :-P
