--- In lpc2000@yahoogroups.com, "luvpc2129" <luvpc2129@y...> wrote:
> I am trying to recieve messages on LPC2129 with Extended
> Identifiers.The sample code given in the files works well for normal
> identifiers but when i tried to recieve Extended Identifiers over
> CAN my C1RID field reads as 0x00 or 0xFF
> i already set the CIRFS register with proper value but its still not
> reading the identifier field proerply.Has anyone faced a similar
> problem......im open to all suggestions.
> C1RFS = 0X80080400;
> Regards
> Micheal
I'm using extended identifiers fine with code based on the
LPC_CANAll.zip example. The FullCAN does not work for extended
identifiers.
I found only one problem in LPC_CANAll. The code did not clear
pending errors on initialisation
pSFR = (unsigned int *) &C1MOD + offset; // Select Mode register
*pSFR = 1; // Go into Reset mode
// Start of added code
pSFR = (unsigned int *) &C1CMR + offset; // Select command register
*pSFR = 0x0E; // Clear receive buffer, data overrun, abort tx
// End of added code
pSFR = (unsigned int *) &C1IER + offset; // Select Interrupt Enable
Register
*pSFR = 0;// Disable All Interrupts
