Lpc2000
Unable to access ext memory on EVBA7 with 144 Pin Adapter
2004-08-22 by helicopterproject2003
I have a EVBA7 with a 144 pin adapter with a LPC2214 chip. The
adapter has 1MB of RAM which I think starts at 0x80000000. I also
belived it is hardware straped to startup in 32bit data bus mode.
I can't seem to write anything into this memory. Even if I use the
JTAG and IAR debugger to set any memory location above 0x8000000 it
stays set to zero which makes it appear to not be working at all or
incorrectly addressed.
Anyone have any ideas?
Thanks
Rick
Re: Unable to access ext memory on EVBA7 with 144 Pin Adapter
2004-08-23 by philips_apps
Rick,
The 144 Pin Adapter has 1 Mbyte of RAM which is organized as 256K x
32 ( Two 16 bit RAM chips). The start address of the external RAM is
0x81000000 ( Bank 1, EMC )
The following registers must be initialized to enable the
read/write/execute access.
   /* Connect A2 - A19, WE and CS1 */
   *pinsel2 = 0xC6009E4;
   /* Initialize Bank1 config in EMC, 32 bit with minimum waits */
   *bcfg1 = 0x20000400;
V18A(143), V3A(14),VSSA(139) and VSSA_PLL(138) power supply pins are
not connected on the adapter. These pins needs to be connected if you
are using the PLL and ADC.
Philips Apps
--- In lpc2000@yahoogroups.com, "helicopterproject2003"
> Thanks
> Rick
2004-08-24 by helicopterproject2003
I guess this means there is no way to use the ext RAM to load
program code for debugging purposes as you would the on-board RAM
because it is not available at reset.
My program has grown larger than the onboard 16K of memory. I was
hoping to use the ext RAM for testing and debugging by loading the
program code into this RAM by the JTAG. This would allow for many
more breakpoints than loading the program into flash.
Am I understanding your answer correctly that this is not possible?
Rick
--- In lpc2000@yahoogroups.com, "philips_apps" <philips_apps@y...>
wrote:
> Rick,
x
is
are
you
> Philips Apps
also
it
or
> > Thanks
> > Rick
2004-08-24 by ian48harry
Rick:
If you have access to JTAG, built-in on EVBA7, then just use the
supplied PathFinder debugger to manually set-up the external RAM,
then load the code at that address.  Or, of course allow the flash to
hold the code that initiallises the external RAM, or ...
Ian
> Rick
> wrote:
> > Rick,
> x
> is
> are
> you
> > Philips Apps
> also
mode.
> the
0x8000000
> it
all
> or
> > > Thanks
> > > Rick
