Lpc2000
sample IAP code
sample IAP code
2004-08-26 by shaneprobinson2000
Hi all, I'm just starting to work with the In Application
Programming and I was wondering if anyone has some simple c code
that stores some calibration variables into flash.  Thanks,
Shane.
sample IAP code
2004-08-27 by Owen Mooney
Here it is:
Setup strucure defined in RAM
struct SETUP {
    ... // fill in the gaps with your data
One copy of the structure in RAM
struct SETUP setup;
Pointer to the non volatile copy
struct SETUP * nonvolatile;
nonvolatile= (struct SETUP*) 0x1C000; // Points to page 14 in Flash
(LPC2106)
copy to RAM (if you need)
setup=*nonvolatile;
now modify it as you need
Then save it - this is for a 14.745 MHz Xtal
#define IAP_LOCATION 0x7ffffff1
void savesetup(struct SETUP *setup){
   typedef void (*IAP)(unsigned int [],unsigned int[]);
   unsigned int command[5];
   unsigned int result[2];
   IAP iap_entry;
   __ARMLIB_disableIRQ();
   iap_entry=(IAP) IAP_LOCATION;
   // get part ID
   command[0]=54;
   result[0]=0;
   iap_entry(command, result); // I do this just for a laugh
   // result in result[1]
   // prepare to erase
   command[0]=50;
   command[1]=14;
   command[2]=14;
   if (result[0] != 0) goto error;
   // erase
   command[0]=52;
   command[1]=14;
   command[2]=14;
   command[3]=14745;
   iap_entry(command, result);     // erase the block - else you get old
+ new data mixed !!!
   // prepare to program
   command[0]=50;
   command[1]=14;
   command[2]=14;
   //  program
   command[0]=51;
   command[1]=0x1C000;
   command[2]=(int)setup;
   command[3]=512;
   command[4]=14745;
   __ARMLIB_enableIRQ();
   return;
   error:
   printf("bum");
It works well be me. make your your program doesn't get up to page 14 of
Flash !!!!
Owen Mooney
