Lpc2000
two match values on one pin?
2004-09-07 by supertoll_trinity
i use in the lpc2124 the pwm to create a 4mhz signal but i also need
a signal with a frequenzy of the twothousandth part with a pulsewidth
of 0.05% (like a needle) to reset a cmos-linesensor. so i create
interrupts of 4mhz and count with an value to 2000. when the value is
1 i set an i/o pin, if it's 2 i clear it. but it only works with a
frequenzy up to 0.8mhz, otherwise the interruptroutine is to slow.
so i had an another idea: with timer 0 i create my 4mhz pwm-signal
and with timer1 and the MRx i want to create the needle-signal. but
in this case i have to toggle one External Match Output's with two
different MRx. but i think that is not possible.
do you have an idea how i can handle it?
thanx
