[LPC2104] hardware bug...
2004-09-09 by Pawel Sikora
# a simple testcase #
typedef volatile unsigned int reg32;
#define __DECLARE_IO_REG32_BIT(name) \
typedef volatile union { \
name##_bits bit; \
reg32 reg; \
} name##_bits_t
typedef struct {
reg32 MR0INT :1;
reg32 MR0RES :1;
reg32 MR0STOP :1;
reg32 MR1INT :1;
reg32 MR1RES :1;
reg32 MR1STOP :1;
reg32 MR2INT :1;
reg32 MR2RES :1;
reg32 MR2STOP :1;
reg32 MR3INT :1;
reg32 MR3RES :1;
reg32 MR3STOP :1;
reg32 :20;
} __mcr_bits;
__DECLARE_IO_REG32_BIT(__mcr);
#define T0MCR (*(__mcr_bits_t *)0xE0004014)
void test()
T0MCR.reg = 0x00000000; // dumpT0MCR -> 0x00000000
/* disassembled code
mov r2, #-536870912
add r2, r2, #16384
add r2, r2, #20
mov r3, #0
str r3, [r2, #0] // r2 == 0xe0004014
#if 0
T0MCR.reg |= 0x01; // dumpT0MCR -> 0x00000001
T0MCR.reg |= 0x02; // dumpT0MCR -> 0x00000003
ldr r3, [r2, #0]
orr r3, r3, #1
str r3, [r2, #0]
ldr r3, [r2, #0]
orr r3, r3, #2
str r3, [r2, #0]
#else
T0MCR.bit.MR0INT = 1; // dumpT0MCR -> 0x00000101
T0MCR.bit.MR0RES = 1; // dumpT0MCR -> 0x00000303
ldrb r3, [r2, #0]
orr r3, r3, #1
strb r3, [r2, #0]
ldrb r3, [r2, #0]
orr r3, r3, #2
strb r3, [r2, #0]
#endif
# possible STRB behaviour (tested with T0MCR and T0IR)
[address][7:0] = Rn[7:0]
[address][15:8]= Rn[7:0]
Could anyone confirm this?
Do you Yahoo!?
Read only the mail you want - Yahoo! Mail SpamGuard.
http://promotions.yahoo.com/new_mail
