does watchdog work ?
2004-09-15 by douglasbolton
I can't get the watchdog timer to work. I set up with the following // set watchdog to be 1 second WDTC = 15000000; // enable the watchdog interrupt WDMOD = 1; WDFEED = 0xAA; WDFEED = 0x55; I then feed every loop of code. Even if I continually feed after set up the WDTOF and WDINT flags get set.
2004-09-15 by cd_racer2
Initialization:
/* Setting watchdog work mode */
WDMOD |= WDMOD_WDEN;
WDMOD |= WDMOD_WDRESET;
/* Dropping watchdog timeout flag */
WDMOD &= ~WDMOD_WDTOF;
/* Setting watchdog timeout */
WDTC = WatchdogTimeout;
WDFEED = 0xAA;
WDFEED = 0x55;
Reset each cycle:
WDTC &= ~WDMOD_WDTOF;
/* Feeding 0xAA, 0x55 to restart watchdog */
WDFEED = WDFEED_WDFEED(0xAA);
WDFEED = WDFEED_WDFEED(0x55);
This code is from our Watchdog driver. We've successfully test it.2004-09-15 by markcrow
A side note to all those working on the LPC22xx chips and using external memory: When the watchdog times out it will try to access vector memory at relative 0x00000000 using the memory attached to CS0 (instead of address 0 of the internal flash memory). --- In lpc2000@yahoogroups.com, "cd_racer2" <cd_racer@m...> wrote: > Initialization: > > /* Setting watchdog work mode */ > WDMOD |= WDMOD_WDEN; > WDMOD |= WDMOD_WDRESET; > /* Dropping watchdog timeout flag */ > WDMOD &= ~WDMOD_WDTOF; > /* Setting watchdog timeout */ > WDTC = WatchdogTimeout; > > WDFEED = 0xAA; > WDFEED = 0x55; > > ----------------------------------------------- > Reset each cycle: > > WDTC &= ~WDMOD_WDTOF; > /* Feeding 0xAA, 0x55 to restart watchdog */ > WDFEED = WDFEED_WDFEED(0xAA); > WDFEED = WDFEED_WDFEED(0x55); > > This code is from our Watchdog driver. We've successfully test it.
2004-09-15 by willyd106
FWIW:
The following routine worked for me. I used P0.4 &5 to be able to
see an i/o pin assert and de-assert using the Keil MCB2100(no
expansion bus):
void init_WDT (void){
WDTC = 0xFF;
WDMOD= 0x03;
WDFEED=0xAA;
WDFEED=0x55;
void init_iopins4and5 (void){
PINSEL0=0x0;
IODIR0=0x00000030;
IOCLR0 = 0x00000030;
long count;
long spare;
int main (void) {
count=0x0;
spare=0x0;
/* Establish Port 0 bit 4 and 5 as outputs and
de-assert both */
init_iopins4and5();
if (WDMOD==0x04)
IOSET0=0x00000020; //P0.05 set
else
spare++;/*startup the watchdog timer
- watchdog interrupt enable = 1
- watchdog reset enable = 1
SO when WDEN and Watchdog timeout happens, a hardware reset should
occur
init_WDT();
if (WDMOD==0x03)
IOSET0 =0x00000010; //set P0.04
else
spare++;
while (1);
Will
CS0 > (instead of address 0 of the internal flash memory). > > > --- In lpc2000@yahoogroups.com, "cd_racer2" <cd_racer@m...> wrote: > > Initialization: > > > > /* Setting watchdog work mode */ > > WDMOD |= WDMOD_WDEN; > > WDMOD |= WDMOD_WDRESET; > > /* Dropping watchdog timeout flag */ > > WDMOD &= ~WDMOD_WDTOF; > > /* Setting watchdog timeout */ > > WDTC = WatchdogTimeout; > > > > WDFEED = 0xAA; > > WDFEED = 0x55; > > > > ----------------------------------------------- > > Reset each cycle: > > > > WDTC &= ~WDMOD_WDTOF; > > /* Feeding 0xAA, 0x55 to restart watchdog */ > > WDFEED = WDFEED_WDFEED(0xAA); > > WDFEED = WDFEED_WDFEED(0x55); > > > > This code is from our Watchdog driver. We've successfully test > it.
