Lpc2000
Testing newly designed LP2106 Board
2004-09-15 by Chris Graham
I've designed an LP2106 board that includes a few special features I need
such as MIDI, an EPROM, etc.  I've had the alpha PCB manufactured and
intalled the parts, and am now testing.  (If I can get this working, I may
make the design available in the list archives as its MIDI capabilites could
be useful to others)
I put a JPG of the schematic here
http://members.shaw.ca/photonwind/Images/Processor%20Schematic.JPG.
I first populated the power supply parts and verified that the voltages were
correct.  Then I populated all the parts related to the processor, reset,
and the MAX3221 serial converter.
I'm now trying to get the bootloader to work.  I installed the jumper to tie
P0.14 low, started up the Philips bootload utility, set 9,600 baud and set
the crystal frequency to 14746 khz to match the board's crystal.
Then I pressed the "Upload to Flash" button and hit the reset button  when
promped.  The board does not respond.  I can trace the RS232 signal from the
PC through the MAX3221 to the correct pin on the LP2106.  I also verified
that the Reset button is pulling the RST pin low, and the P0.14 pin is
really pulled low.
I see no signal being returned by the board out of TXD0 to the MAX3221.
I've done all this in the past with a TiniArm board and the setup external
to the board is the same, so I know generally what I'm doing.
Is this a reasonable way to test a new board?  Have I overlooked anything?
Thanks in advance.
- Chris
Re: [lpc2000] Testing newly designed LP2106 Board
2004-09-15 by Robert Adsett
At 02:25 PM 9/15/04 -0700, you wrote:
<snip>
>really pulled low.
Have you verified that the clock is running?
Next question would be are connected to an input pin on the MAX?
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Thanks Robert,
Yes I can see the clock on my oscilloscope scope and the frequency is
correct to the accuracy I can measure.
I can see the RS232 signal at the board input with the oscilloscope, and I
can also see a logic level version of the signal coming out of the MAX, and
arriving the RXD0 pin of the LP2106.  When I check the TXD0 pin I see no
signal.
- Chris
At 02:36 PM 9/15/04 -0700, you wrote:
>Thanks Robert,
>signal.
OK, I'd do two things.  Not necessarily in this order.
- lift the Max pin that is connected to the TXD0 pin and then check the TXD
pin for output.  That will verify it's not just being pulled down by the MAX.
- Use a simple terminal program and go through the initial startup sequence
by hand.  It's a lot easier to repeat that way and the timing is totally
under your control.
Hmm, a thought springs to mind.  An earlier poster ran into a problem with
ISP and it turned out to be insufficient decoupling (on his driver chip if
I remember correctly).
Also check the pin that takes the micro into JTAG mode, I don't remember if
that is a potential problem and I don't have the reference to hand but it's
worth verifying.
Robert
                         Kelvin Throop, III
Re: Testing newly designed LP2106 Board
2004-10-06 by Greg
--- In lpc2000@yahoogroups.com, "Chris Graham" <chris_e_gr@y...>
I need
and
working, I may
capabilites could
voltages were
reset,
jumper to tie
and set
button  when
signal from the
verified
pin is
> really pulled low.
MAX3221.
external
anything?
> Thanks in advance.
Chris
Is pins 17 and 40 really not connected, as per your schematic?
With no I/O supply, I expect you won't be getting any I/O.
Hope this helps.
Greg
Re: [lpc2000] Re: Testing newly designed LP2106 Board
2004-10-06 by Chris Graham
> Hope this helps.
> Greg
Thanks Greg.  Yes, that was my dumb mistake!  I did eventually found it when
checking the voltages on all the pins of the CPU, installed a jumper to make
the connection, and like magic the board started working.  :-)))
Actually I did have them connected at one point, but must have accidentally
deleted the wire when I extracted the CPU circuit from a larger circuit that
contained other things.
- Chris
