Lpc2000
Constructors
Constructors
2004-09-20 by Rodrigo Cesar da Silva Martins
How can I use class constructors with gnu arm? I'm using a LPC2129 and
Keil development system.
For example:
//header file
class SPI
            public:
            SPI(char init);
//source file
SPI::SPI(char init)
//application file
 SPI ADSPI(0); //spi channel for AD converter
The constructor function should be called when I declare an object, but
it doesn't happen.
Thanks in advance,
Rodrigo Martins
Intermetric Instrumentos Ltda
(11) 4761-8009
rodrigo@...
Re: [lpc2000] Constructors
2004-09-21 by Pawel Sikora
> it doesn't happen.
Probably the startup code and linker script don't
support .ctors and .dtors sections.
The .ctors and .dtors sections are lists of function
pointers to global c++ object constructors
and destructors.
Do you Yahoo!?
New and Improved Yahoo! Mail - 100MB free storage!
http://promotions.yahoo.com/new_mail
Re: Constructors
2004-09-22 by dave_albert
Here's a snippet of code I use to call C++ constructors in crt0.S
I call it after clearing .bss and initializing .data:
     /* Call global C++ object constructors */
     ldr     r4, =__CTOR_LIST__      @ Null terminated list of ctors
Ctor_Loop:
     ldr     r5, [r4], #+4           @ Fetch constructor address
     cmp     r5, #0                  @ Test for end of list
     addne   lr, pc, #4              @ Save return address
     movne   pc, r5                  @ Call constructor
     bne     Ctor_Loop               @ Continue for all constructors
Good luck!
--- In lpc2000@yahoogroups.com, "Rodrigo Cesar da Silva Martins"
> For example:
> //header file
> class SPI
>             public:
>             SPI(char init);
> //source file
> SPI::SPI(char init)
> //application file
> it doesn't happen.
> Thanks in advance,
> Rodrigo Martins
> (11) 4761-8009
> rodrigo@i...
Re: Constructors
2004-09-22 by Karl Olsen
--- In lpc2000@yahoogroups.com, "dave_albert" <david_albert@h...>
> Ctor_Loop:
Won't the called constructor likely modify the zero flag so that
the "bne Ctor_Loop" might terminate the loop prematurely?
Karl Olsen
Re: Constructors
You're absolutely right...thanks Karl!
Clearly my constructors aren't doing any comparisons that set the zero
flag (since this works for me)
per Karl's comment, the comparison of r5 to zero should be done again
after the constructor returns and before the bne... and then there are
probably more elegant solutions.
> > Ctor_Loop:
> Karl Olsen
Re: Constructors
2004-09-25 by dave_albert
Note that you will also need to modify your linker script.  Mine has
the following immediately after the .text segment:
                /* Build table of global constructors to call */
                __CTOR_LIST__ = .;
                *(.ctors)
                LONG(0)
                __CTOR_END__ = .;
                /* Build table of global destructors to call on exit*/
                __DTOR_LIST__ = .;
                *(.dtors)
                LONG(0)
                __DTOR_END__ = .;
> > > Ctor_Loop:
> > Karl Olsen
