hi, yes correct. 60mhz is the max at the minute
if u are just getting started tehre is a pll calculator program in
the Files section of this group which may be of assistance for you
to see the possible clock speeds and various divider settings needed.
With regard to faster core speeds then I was talking to a guy from
philips a couple of weeks ago and it was hinted that faster cores
will be available in the future as teh current architecture should
work up to around 80mhz...i may be off here, but that was my
understanding at the time...
however the current hardware is limited to 60mhz.
one of the reasons for the VPBDiv is that in the future with a
faster core clock, the Peripherals (eg RTC, UART, etc etc) that run
of the VPB bus may not be able to run at the full core speed. At
present however they are capable to run at the maximum clock speed
of 60mhz.
as robert says reducing teh vpb speed will lower power consumption.
u could obviously also look at powering down the peripherals u dont
need if u are only concerned with the GPIO and still maintaining the
60mhz clock.
hope this helps
rgds
pete
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@a...>
wrote:
> At 08:42 PM 10/6/04 +0000, you wrote:
> >This is my first ARM project so please excuse me if this is a dumb
> >question.
> >I have an application where I need maximum GPIO speed. The
> >datasheet mentions that a VPB divider greater than 1 is needed at
> >max processor clock speeds but I cannot find what that speed is.
> >What is the max clock speed for the VPB (GPIO) bus?
> Not a dumb question, it's not documented anywhere (at least I've
not seen
> it). A VPB of 1 appears to work with no problem up to 60MHz. I
suspect
> that the VPB is in there primarily for two reasons right now, 1-
by
> reducing the peripheral clock speed you can reduce the power
consumption of
> the peripherals and 2- if/when they go to a higher max speed they
can
> document a lower max for the VPB and the HW already exists. There
is an
> interesting note in the RTC section that talks about higher
envisioned bus
> speeds.
> Robert
> " 'Freedom' has no meaning of itself. There are always
restrictions,
> be they legal, genetic, or physical. If you don't believe me, try
to
> chew a radio signal. "
> Kelvin Throop, III
