> Hi Peter
> Interesting to hear this as I too am using Keil, but wasnt aware
> that you could do this!
> For my info, how do you tell Keil that you want the interrupt to be
> a Fast interrupt rather than the normal type?
> sorry i didnt help fix the problem, and hope someone else can help u
> out.
> rgds
> pete
> --- In lpc2000@yahoogroups.com, "peterburdine" <lordofdawn@h...>
> wrote:
> > Pete,
> > The Keil's compilier does not require such initialization. I have
> a
> > timer isr that works just fine being declared as
> > void timer_isr (void);
> > void timer_isr (void) __irq {....}
> > I do now have the VicVectAddr = 0;, but that doesn't help if it
> > doesn't get called.
> > --Peter
> > --- In lpc2000@yahoogroups.com, "Pete" <peterbrown_abroad@y...>
> wrote:
> > > peter
> > > i think also that you need to initialise the isr function
> > > differently...
> > > something like this:
> > > void uart0_isr(void) __attribute__ ((interrupt("IRQ")));
> > > rather than:
> > > void uart0_isr (void);
> > > see the user manual section on interrupt handling....
> > > also, add the:
> > > VICVectAddr = 0;//Dummy write to signal end of interrupt
> > > to the end of the isr...
> > > does this help?
> > > kind regards
> > > Pete
> > > wrote:
> > > > I am sure the might help, if the ISR was called in the first
> > > place.
> > > > But it isn't.
> > > > Also, according to the user manual I have,, it states that
> only
> > > U0IIR
> > > > must be accessed to clear the IRQ (for TXRE anyways).
> > > > --Peter
> > > wrote:
> > > > > In an interrupt service routine:
> > > > > in order to exit it properly you must, Clear the interrupt
> flag
> > > that
> > > > > triggered it (write a 1 to the flag?) eg:
> > > > > U0IIR = 0x0000000A; //Clear the interrupt register
> > > > > anyway, most importantly you also need to write to teh
> vector
> > > > > address register:
> > > > > eg:
> > > > > VICVectAddr = 0x00000000;//Dummy write to signal end of
> > > interrupt
> > > > > failure to do these will lead to continuous interrupts.....
> > > > > Does this help???
> > > > > rgds
> > > > > pete
> <lordofdawn@h...>
> > > > > wrote:
> > > > > > I think I may be missing something stupid, but can anyone
> help
> > > me?
> > > > > > I am tring to write to UART0, but it doesn't seem to
> work. I
> > > am
> > > > > > trying to write a software buffer to help out the one byte
> > > hardware
> > > > > > buffer. Specifically I am using the LPC 2294. Below is
> my
> > > code.
> > > > > > I am using the Keil toolset
> (compiler/debugger/simulator).
> > > The
> > > > > code
> > > > > > works perfectly fine when running it on the simulator, but
> > > when I
> > > > > try
> > > > > > to run it on the chip, I will only get "ho" instead
> > > of "hello". I
> > > > > put
> > > > > > some break points in it when using JTAG to debug, but the
> ISR
> > > is
> > > > > never
> > > > > > called when running on the real hardware, it is called on
> the
> > > > > > simulator. Also, when I debug on JTAG I never se the THRE
> or
> > > TEMT
> > > > > > clear. Can you see anything obviously wrong? I think I
> put in
> > > > > > everything that you need to compile it.
> > > > > > #include <stdio.h>
> > > > > > #define TX_BUFFER_LENGTH 64
> > > > > > #define UART0_THRE (U0LSR & 0x20)
> > > > > > #define PINSEL0_00_TxD (0x01)
> > > > > > #define PINSEL0_01_GPIO (0x00 << 2)
> > > > > > #define U0RBR (*((volatile unsigned char *)
> > > 0xE000C000))
> > > > > > #define U0THR (*((volatile unsigned char *)
> > > 0xE000C000))
> > > > > > #define U0IER (*((volatile unsigned char *)
> > > 0xE000C004))
> > > > > > #define U0IIR (*((volatile unsigned char *)
> > > 0xE000C008))
> > > > > > #define U0FCR (*((volatile unsigned char *)
> > > 0xE000C008))
> > > > > > #define U0LCR (*((volatile unsigned char *)
> > > 0xE000C00C))
> > > > > > #define U0MCR (*((volatile unsigned char *)
> > > 0xE000C010))
> > > > > > #define U0LSR (*((volatile unsigned char *)
> > > 0xE000C014))
> > > > > > #define U0MSR (*((volatile unsigned char *)
> > > 0xE000C018))
> > > > > > #define U0SCR (*((volatile unsigned char *)
> > > 0xE000C01C))
> > > > > > #define U0DLL (*((volatile unsigned char *)
> > > 0xE000C000))
> > > > > > #define U0DLM (*((volatile unsigned char *)
> > > 0xE000C004))
> > > > > > #define VICVectAddr6 (*((volatile unsigned long *)
> > > 0xFFFFF118))
> > > > > > #define VICVectCntl6 (*((volatile unsigned long *)
> > > 0xFFFFF218))
> > > > > > #define VICIntSelect (*((volatile unsigned long *)
> > > 0xFFFFF00C))
> > > > > > #define VICIntEnable (*((volatile unsigned long *)
> > > 0xFFFFF010))
> > > > > > #define VICIntEnClr (*((volatile unsigned long *)
> > > 0xFFFFF014))
> > > > > > static Uint16 txBytes = 0;
> > > > > > static Uint16 txRdPos = 0;
> > > > > > static Uint16 txWrPos = 0;
> > > > > > static Uint16 txBuffer[TX_BUFFER_LENGTH];
> > > > > > void uart0_config (void);
> > > > > > void uart0_sendByte (Uint8);
> > > > > > int putchar(int);
> > > > > > int main (void);
> > > > > > void uart0_config (void) {
> > > > > > // Setup UART 0
> > > > > > U0LCR = 0x80; // Enable DLAB
> > > > > > U0DLL = 0x16; // Setup BGR
> > > > > > U0DLM = 0x05; // ~2400 Bit/s @ 50 Mhz
> > > > > > U0LCR = 0x03; // Enable UART 0, 8 bits, no parity, 1
> stop bit
> > > > > > // Reset the FIFOs
> > > > > > U0FCR = 0xC7; // RX FIFO trigger level 8 chars,
> reset tx and
> > > > > rx fifo,
> > > > > > enable fifos
> > > > > > // Setup Interrupts for UART0
> > > > > > U0IER = 0x7;
> > > > > > VICIntSelect &= 0x0;
> > > > > > VICVectCntl6 = 0x20 | 6;
> > > > > > VICVectAddr6 = (unsigned long) uart0_isr;
> > > > > > VICIntEnable |= (0x1 << 6); // Enable Uart0 Interrupt
> > > > > > void uart0_isr (void) __irq {
> > > > > > switch((U0IIR>>1)&0x7) {
> > > > > > // THRE
> > > > > > case 001:
> > > > > > if(txBytes != 0) {
> > > > > > U0THR = txBuffer[txRdPos];
> > > > > > txRdPos++;
> > > > > > txRdPos = (txRdPos ==
> > > > > TX_BUFFER_LENGTH)?0:txRdPos;
> > > > > > txBytes--;
> > > > > > break;
> > > > > > void uart0_sendByte(Uint8 byte) {
> > > > > > // Wait until there is room in the buffer
> > > > > > while(txBytes == TX_BUFFER_LENGTH);
> > > > > > VICIntEnClr |= (1 << 6);
> > > > > > if(!UART0_THRE) { // Put it in the software buffer
> > > > > > txBuffer[txWrPos] = byte;
> > > > > > txWrPos++;
> > > > > > txWrPos = (txWrPos == TX_BUFFER_LENGTH)?
> 0:txWrPos;
> > > > > > txBytes++;
> > > > > > else { // If the chip buffer is empty, put it there
> > > > > > U0THR = byte;
> > > > > > VICIntEnable |= (1 << 6);
> > > > > > int putchar(int a) {
> > > > > > uart0_sendByte((int)a);
> > > > > > int main (void) {
> > > > > > PINSEL0 = PINSEL0_00_TxD | PINSEL0_01_RxD;
> > > > > > printf("hello");
