Lpc2000
2104 makefile
2104 makefile
2004-10-10 by sanjay_varma_bh
Iam newuser of gcc. I want to work with lpc2104. Unfortunately i
could nt get make file for 2104. So I modified the 2106 rom.ld,ram.ld
to work it for 2104.
I just changed the length of SRAM to 16k from 64k. But this is not
working.
Can anyone help me where can I find the 2104 ram.ld,rom.ld,boot.s and
makefile.
Re: [lpc2000] 2104 makefile
2004-10-10 by Robert Adsett
>working.
Hmm, that should have worked.  It is possible that the control file you
were using had to be changed in multiple places or that the startup had the
ram size/locations hardwired and needed to be changed as well.
In any case the lpc newlib support at
http://www.aeolusdevelopment.com/Articles/download.html has a linker script
and startup file that supports the 2104.  The linker script can be modified
simply to support the 2105 or 2106, no changes need to be made to the
startup assembly.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
