lpc2294 external bus query
2004-10-12 by itsjustimpossible
Hi Does anyone know if it is possible to run with internal FLASH and RAM, but also have an additional SRAM and 8-bit peripheral on the external bus? From the data sheet it looks like it should be, but if I run from internal FLASH I don't get any bus activity if I try to access the external memory. many thanks Simon
2004-10-12 by Robert Wood
Hi Simon, >> Does anyone know if it is possible to run with internal FLASH and RAM, but also have an additional SRAM and 8-bit peripheral on the external bus? << I bl**dy well hope it does, otherwise I'm stuffed! <g> >> >From the data sheet it looks like it should be, but if I run from internal FLASH I don't get any bus activity if I try to access the external memory. << I've only just got my board back, so haven't actually tried it yet, but one suggestion would be to check whether you've set up the registers (PINSEL0-2) to configure the relevant pins as address and data lines. The only other thing I can think is that you haven't setup the compiler to access *external* RAM for the relevant locations... Cheers, Rob
2004-10-12 by Bill Knight
Yes it is possible. The LPC-SBC2 at http://www.theARMPatch.com operates in that manner. It uses internal flash for program space, internal RAM for stack space, external RAM for variables and buffers, and accesses its ethernet controller and CompactFlash interface on the external bus. Regards -Bill Knight www.theARMPatch.com On Tue, 12 Oct 2004 14:53:18 -0000, itsjustimpossible wrote: Hi Does anyone know if it is possible to run with internal FLASH and RAM, but also have an additional SRAM and 8-bit peripheral on the external bus? From the data sheet it looks like it should be, but if I run from internal FLASH I don't get any bus activity if I try to access the external memory. many thanks Simon
2004-10-12 by douglasbolton
--- In lpc2000@yahoogroups.com, "itsjustimpossible" <simonjh@b...> wrote: > > Hi > Does anyone know if it is possible to run with internal FLASH and > RAM, but also have an additional SRAM and 8-bit peripheral on the > external bus? > > From the data sheet it looks like it should be, but if I run from > internal FLASH I don't get any bus activity if I try to access the > external memory. > > many thanks > Simon You sure can. I'm currently running an external 8 bit lcd and 2*16 bit sram chips. I also use both the internal flash and sram. I'm using CS1,CS2 and CS3 for the external devices. Below is my setip code and it seems just to work! dummy = PINSEL2; // set extended memory D0-D16 CS,CS1,CS2,CS3 A0-A19 dummy &= ~(0x00000020); dummy |= 0x00000010; // enable /WE,/CS1 dummy |= 0x00000900; // enable /CS2,/CS3 dummy |= 0x00014000; // enable A0,A1, A2-A19 dummy |= 0x0d800000; PINSEL2 = dummy; // set up the external sram on CS1 dummy = BCFG1; // 1 idle cycle dummy &= ~(0x0000000f); // 3 wait states, 16 bit wide bus dummy &= ~(0x000003e0); dummy |= 0x00000460; // 3 wait states dummy &= ~(0x0000f800); dummy |= 0x00001800; // 16 bit bus dummy &= ~(0x30000000); dummy |= 0x10000000; BCFG1 = dummy; // set up the external non volatile sram on CS2 dummy = BCFG2; // 1 idle cycle dummy &= ~(0x0000000f); // 3 wait states, 16 bit wide bus dummy &= ~(0x000003e0); dummy |= 0x00000460; // 3 wait states dummy &= ~(0x0000f800); dummy |= 0x00001800; // 16 bit bus dummy &= ~(0x30000000); dummy |= 0x10000000; BCFG2 = dummy; // set up the lcd on CS3 dummy = BCFG3; // maximum idle cycles dummy |= 0x0000000f; // maximum wait cycles dummy |= 0x000003e0; // maximum wait cycles dummy |= 0x0000f800; // 8 bit bus dummy &= ~(0x30000000); BCFG3 = dummy;
2004-10-13 by itsjustimpossible
Thats great! I had setup the EMC config, but had bypassed the PINSEL2 register when compiling for internal FLASH! I have added another section to the start-up file to configure PINSEL2 and magically everything works as expected. many thanks Simon --- In lpc2000@yahoogroups.com, "douglasbolton" <doug@c...> wrote: > > --- In lpc2000@yahoogroups.com, "itsjustimpossible" <simonjh@b...> > wrote: > > > > Hi > > Does anyone know if it is possible to run with internal FLASH and > > RAM, but also have an additional SRAM and 8-bit peripheral on the > > external bus? > > > > From the data sheet it looks like it should be, but if I run from > > internal FLASH I don't get any bus activity if I try to access the > > external memory. > > > > many thanks > > Simon > > You sure can. I'm currently running an external 8 bit lcd and 2*16 > bit sram chips. I also use both the internal flash and sram. > > I'm using CS1,CS2 and CS3 for the external devices. Below is my setip > code and it seems just to work!
