Lpc2000
LPC2106 UART0
LPC2106 UART0
2004-10-17 by mike robins
I purchased an LPC2106 board from olimex with a 14.7456 MHz crystal.
I'm having a very difficult time getting the serial port to work and output to the screen.
I'm trying to transmit at 57600,8,1,n.
The mcu osc is set up for 4 times the crystal.
I programmed the board with a precompiled uart program that echos characters back, and it worked fine, so the connections are good and the uc works.
Here is the code:
#include <C:\GNUARM\bin\lpc210x.h>
int main(void);
void Init(void);
void Delay (unsigned long a);
int main(void)
 Init();     //Initialize clock
  IODIR=0x000000080;           //P0.7 is output(LED)
  //Setup UART
  PCONP &= 0x08;
  UART0_IER = 0x00;
  UART0_LCR = 0x80;
  UART0_DLL = 0x20;
  UART0_DLM = 0x00;
  UART0_LCR = 0x03;
  UART0_FCR = 0x07;
 while (1)
  // flash LED
   IOCLR |= 0x00000080;                    //LED on
      Delay(100000);
      IOSET |= 0x00000080;                     //LED off
      Delay(100000);
  // Transmit Hi
  while((UART0_LSR & 0x40) == 0){}
   UART0_THR = 'H';
   UART0_THR = 'i';
void Init(void)
 // Init PLL
    PLLCFG=0x23;                 // P=2, M=4, PLLfreq = 235,9296 Mhz, CCLK = 58,9824 Mhz
    PLLFEED=0xAA;     // 14.7456MHz
 PLLFEED=0x55;
    PLLCON=0x01;                 // Enable the PLL
    PLLFEED=0xAA;
 PLLFEED=0x55;
    while(!(PLLSTAT & 0x0400)){}  // Wait for PLL to lock
    PLLCON=0x03;                 // Connect PLL as clock source
    PLLFEED=0xAA;
 PLLFEED=0x55;
    //Init MAM & Flash memory fetch
 MAMTIM=0x07;
 MAMCR=0x00;
 MAMMAP=0x01;
    VPBDIV=0x01;                 //pclk = cclk
    while (--a!=0){}
The code flashes the LED but "Hi" is not sent???
Any help would be greatly appreciated.
Do you Yahoo!?
vote.yahoo.com - Register online to vote today!
Re: [lpc2000] LPC2106 UART0
2004-10-17 by Robert Adsett
>uc works.
It doesn't look like you've set up the UART pins (PINSEL0)
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Re: LPC2106 UART0
2004-10-17 by mkrbns
Okay it works now.  Thank you.
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@a...>
crystal.
and
and the
> >uc works.
> Robert
restrictions,
to
>                          Kelvin Throop, III
