Lpc2000
Looking for low cost toolchain for LPC2106
2004-10-19 by rudyvanraemdonck
Here is my situation:
I have currently developed (and am selling) a number of intelligent
IO cards for model railroad control. The modules are based on
ATMega8 (which I love). All modules are linked up to a RS485 network
(up to 127) and talk to a PC (486@66MHz) running DOS. Yes, you read
well, DOS! This is because the program to control the railroad
(collision prevention, acceleration/decelleration of trains) must
run in real-time.
Next step is to develop a small controller to which I will port the
DOS application (about 15.000 lines of PASCAL code). For this
project I am very interested in using the LPC2106.
Since my controller will be manufactured in limited series
(batches of 10 or 20), and since I am a one man company, I am
looking for a low cost tool chain to develop, simulate, debug my
application. Preferrably I would like to have no code size limit as
in most starter kits (e.g. Hitex). Also I am using a Windows PC as a
host system
(Multi edit editor, GCC or Imagecraft ARM compiler when it will be
available).
One idea could be to buy a code size limited starter kit to test and
debug the hardware abstraction layer (uart driver, comm protocol)
for my application. The moment that is working, I could use the free
Borland C/C++ compiler to write, test and debug the functionality of
my application on PC (in a virtual environment). If all is right,
then I could compile the complete application for the ARM and test
it using classic debug techniques (control a led, send debug
messages over the uart). Of course this is productive than an
emulator but perhaps it could work.
Can anyone give me some good advice please?
Kind regards,
Rudy
Modeltech - Belgium
www.modeltech.be (in Dutch and under construction for the moment)
2004-10-20 by Stephen Pelc
> port the DOS application (about 15.000 lines of PASCAL code).
> For this project I am very interested in using the LPC2106.
> my application.
See:
   www.mpeltd.demon.co.uk/usbstamp.htm
   www.mpeltd.demon.co.uk/tiniarm.htm
As of next week the Development CD will include an evaluation
version of the Rowley tool chain (thanks to Paul and Mike).
Our low cost Forth compiler (GBP 100.00, EU ~145) is limited to
120k code and 64k RAM, which is ideal to fill a 2106.
Stephen
Stephen Pelc, stephen@...
MicroProcessor Engineering Ltd - More Real, Less Time
133 Hill Lane, Southampton SO15 5AF, England
tel: +44 23 80 631441, fax: +44 23 80 339691
web: http://www.mpeltd.demon.co.uk - free VFX Forth downloads
Re: Looking for low cost toolchain for LPC2106
2004-10-22 by tinyarmdev
Dear sir,
look at www.tinyarm.com.
Contact me at info@... if you find our offering interesting.
Yvon
--- In lpc2000@yahoogroups.com, "rudyvanraemdonck" <rudy@m...> wrote:
> Hi,
network
> run in real-time.
a
> host system
> available).
and
free
of
> Kind regards,
> Rudy
> Modeltech - Belgium
Re: [lpc2000] Looking for low cost toolchain for LPC2106
2004-10-27 by micheal jack
Hi
I am using a low price toolchain for chips based on ARM. It include IDE, Emulator, and emulator board. you can view their website www.embedinfo.com.
The price of their tools I think is the cheapest of the world, but the ability of them are good. Maybe you can find what you want.
run in real-time.
host system
available).
Kind regards,
Rudy
Modeltech - Belgium
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
   To visit your group on the web, go to:
http://groups.yahoo.com/group/lpc2000/
Do you Yahoo!?
Yahoo! Mail Address AutoComplete - You start. We finish.
2004-10-27 by Stephen Pelc
> the DOS application (about 15.000 lines of PASCAL code). For this
> as in most starter kits (e.g. Hitex).
Since you have to port the code from language to another (if I
read you correctly), consider using Forth. Our VFX compiler
generates good code. For GBP 165 (~EU 225) you get a compiler
with a 120k code and 64k RAM limit to fit the 2106 and a 2106
board. See
Plus you get multi-tasking, interactive debugging ...
Stephen
P.S. I only got into Forth because I was looking for a portable
Pascal compiler!
Re: [lpc2000] Re: Looking for low cost toolchain for LPC2106
2004-10-28 by Alex Holden
> board. See
 From reading the product manual (I couldn't find it mentioned in the
advert) it appears that we're only allowed to target hardware purchased
from you with the \ufffd165 version of the compiler. If the OP doesn't want
to base the production version of his controller around your TiniARM
module he would have to buy the full version of the compiler for \ufffd1250.
Is that correct?
------------ Alex Holden - http://www.linuxhacker.org ------------
If it doesn't work, you're not hitting it with a big enough hammer
2004-10-29 by Stephen Pelc
>    From: Alex Holden <alex@...>
> mentioned in the advert) it appears that we're only allowed to
> target hardware purchased from you with the £165 version of
> the compiler. If the OP doesn't want to base the production
> version of his controller around your TiniARM module he would
> have to buy the full version of the compiler for £1250. Is
> that correct?
No. You can only use the TiniARM and USB Stamp binaries with
those boards. These are the ones you get when you buy a board
only. What is produced by any version of the cross compiler you
can do what you like with.
The £165 package includes the cross compiler and one board. The
low cost compiler is just restricted to 120kb code and 64kb RAM.
Multitasking and floating point are included. Driver files are
only included for LPC2xxx parts. The £1250 compiler has no
restrictions and includes target code for a state machine
compiler, PID loops and a filing system.
Stephen
Stephen Pelc, stephen@mpeltd.demon.co.uk
2004-10-29 by Alex Holden
Stephen Pelc wrote:
> The \ufffd165 package includes the cross compiler and one board. The
> only included for LPC2xxx parts. The \ufffd1250 compiler has no
My apologies; it seems that I read the statement regarding not being
allowed to target hardware not purchased from you in the manual for the
embedded Forth engine, not the Windows based Forth cross-compiler.
