Lpc2000
Programming GNU hex files
2004-10-22 by peterburdine
I seem to be having problems trying to program my Phycore LPC2994
module when I use the GNU toolset.  I have tried using both JTAG and
the Philips utility, and neither of them will successfully program the
chip.  It will instead have the the previous program.  If I used the
Keil toolset I do not have this problem.  Does anyone have any
suggestions?  I am using uVision 3.
Peter
Re: [lpc2000] Programming GNU hex files
2004-10-24 by Charles Manning
> Thanks,
> Peter
This is most likely something to do with either your start up file or your
ldscript.
Have a look at the two map files and see how they differ, that should give
some clues.
-- CHarles
RE: [lpc2000] Programming GNU hex files
2004-10-24 by Richard Rauscher
I've moved from the Keil uVision3 to a linux hosted GNU build using the
exact same linker script.  Here are the two pertinent targets from the
Makefile, one for linking and one for creating the hex file (which I then
download from my windows system with Philip's LPC210x_ISP utility).
		FW.elf : $(SOBJS) $(COBJS)
		    $(LD) -o FW.elf $(SOBJS) $(COBJS) $(LIBPATH) -lc -lgcc -T Target.ld
		FW.hex : FW.elf
		    arm-elf-objcopy -O ihex FW.elf FW.hex
hth,
--rich
Sent: Sat 10/23/2004 9:18 PM
To: lpc2000@yahoogroups.com; peterburdine
Subject: Re: [lpc2000] Programming GNU hex files
> Thanks,
> Peter
ldscript.
some clues.
-- CHarles
Yahoo! Groups Sponsor
ADVERTISEMENT
click here <http://us.ard.yahoo.com/SIG=129ko57bh/M=295196.4901138.6071305.3001176/D=groups/S=1706554205:HM/EXP=1098677698/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com>
Yahoo! Groups Links
*	To visit your group on the web, go to:
	http://groups.yahoo.com/group/lpc2000/
*	To unsubscribe from this group, send an email to:
	lpc2000-unsubscribe@yahoogroups.com <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Re: Programming GNU hex files
2004-10-25 by dpbevin2k
I had a problem when I moved to a Cygwin hosted GNU build (using a
Phycore 2294).
The hex files downloaded correctly but did not appear to run on the
target. Strangely, the problem was being caused by the order in
which the startup code was structured.
If my startup code was as follows, the file jumped into
the "undefined" vector loop:
<--BEGIN CODE-->
Vectors:
        b     _start                    // reset - _start
        ldr   pc,_undf                  // undefined - _undf
        ldr   pc,_swi                   // SWI - _swi
        ldr   pc,_pabt                  // program abort - _pabt
        ldr   pc,_dabt                  // data abort - _dabt
        nop                             // reserved
        ldr   pc,[pc,#-0xFF0]           // IRQ - read the VIC
        ldr   pc,_fiq                   // FIQ - _fiq
_undf:  .word __undf                    // undefined
_swi:   .word __swi                     // SWI
_pabt:  .word __pabt                    // program abort
_dabt:  .word __dabt                    // data abort
_irq:   .word __irq                     // IRQ
_fiq:   .word __fiq                     // FIQ
__undf: b     .                         // undefined
__swi:  b     .                         // SWI
__pabt: b     .                         // program abort
__dabt: b     .                         // data abort
__irq:  b     .                         // IRQ
__fiq:  b     .                         // FIQ
_start:
// Startup code here
<--END CODE-->
But if I moved the exception loops to below the start code (shown
below), then everything seemed to work fine.
<--BEGIN CODE-->
Vectors:
        nop                             // reserved
_start:
__swi:  b     .                         // SWI
__irq:  b     .                         // IRQ
__fiq:  b     .                         // FIQ
<--END CODE-->
I have no explanation for this but it worked for me (after a couple
of days of head-scratching). If anyone can explain why this is the
case I would love to know!?!?
Hope this helps,
David
--- In lpc2000@yahoogroups.com, "Richard Rauscher" <richard@m...>
using the
I then
> 		FW.hex : FW.elf
> hth,
> --rich
> From: Charles Manning [mailto:manningc2@a...]
and
program the
> > Thanks,
> > Peter
or your
> ldscript.
should give
> some clues.
> -- CHarles
> ADVERTISEMENT
> click here
