Lpc2000
Division function
Division function
2004-11-01 by dean_j_greaves
  I having a problem with some code i'm developing on the LPC2214
chip using GNU tools.
  I have a simple function that performs a division.
  unsigned int a=0, b=1000, c=10;
  a=b/c;
  When i compile up the code and download to the target, the code
breaks when i step over this division routine.  When i step in to the
assembly code for the division, it has compiled in  __divsi3 from the
libgcc library.
  The problem appears to be that just before the return from the
division function, it attempts to restore registers from the stack
that it never actually push onto the stack.
  Has anyone ever come across this before.  Any help would be
gratefully received.
  Dean
Re: [lpc2000] Division function
2004-11-01 by Michael Anburaj
Send the elf file if it's a small piece of code.
-Mike.
--- dean_j_greaves <dgreaves@...> wrote:
> Hi,
> on the LPC2214
>   a=b/c;
> target, the code
> i step in to the
> __divsi3 from the
> libgcc library.
> return from the
> from the stack
> would be
>   Dean
Do you Yahoo!?
Yahoo! Mail Address AutoComplete - You start. We finish.
http://promotions.yahoo.com/new_mail
I just tried it on my setup.
source:
unsigned int test(U32 b, U32 c)
	return b/c;
void APP_vMain (void)
	unsigned int a=0, b=1000, c=0;
	a=test(b,c);
	CONSOL_Printf("a = %d, b = %d, c = %d\n\n",a,b,c);
from the elf image:
40000278 <test>:
40000278:	e1a0c00d 	mov	ip, sp
4000027c:	e92dd800 	stmdb	sp!, {fp, ip, lr, pc}
40000280:	e24cb004 	sub	fp, ip, #4	; 0x4
40000284:	eb000366 	bl	40001024 <__udivsi3>
40000288:	e89da800 	ldmia	sp, {fp, sp, pc}
4000028c <APP_vMain>:
4000028c:	e1a0c00d 	mov	ip, sp
40000290:	e92dd830 	stmdb	sp!, {r4, r5, fp, ip, lr,
pc}
40000294:	e3a05000 	mov	r5, #0	; 0x0
40000298:	e3a04ffa 	mov	r4, #1000	; 0x3e8
4000029c:	e1a01005 	mov	r1, r5
400002a0:	e24cb004 	sub	fp, ip, #4	; 0x4
400002a4:	e1a00004 	mov	r0, r4
400002a8:	ebfffff2 	bl	40000278 <test>
400002ac:	e1a01000 	mov	r1, r0
400002b0:	e59f000c 	ldr	r0, [pc, #12]	; 400002c4
<.text+0x1c4>
400002b4:	e1a02004 	mov	r2, r4
400002b8:	e1a03005 	mov	r3, r5
400002bc:	e89d6830 	ldmia	sp, {r4, r5, fp, sp, lr}
400002c0:	ea000349 	b	40000fec <CONSOL_Printf>
400002c4:	40008efc 	strmid	r8, [r0], -ip
40001024 <__udivsi3>:
40001024:	e2512001 	subs	r2, r1, #1	; 0x1
40001028:	012fff1e 	bxeq	lr
4000102c:	3a000036 	bcc	4000110c <__udivsi3+0xe8>
40001030:	e1500001 	cmp	r0, r1
40001034:	9a000022 	bls	400010c4 <__udivsi3+0xa0>
40001038:	e1110002 	tst	r1, r2
4000103c:	0a000023 	beq	400010d0 <__udivsi3+0xac>
40001040:	e311020e 	tst	r1, #-536870912	; 0xe0000000
40001044:	01a01181 	moveq	r1, r1, lsl #3
40001048:	03a03008 	moveq	r3, #8	; 0x8
4000104c:	13a03001 	movne	r3, #1	; 0x1
40001050:	e3510201 	cmp	r1, #268435456	; 0x10000000
40001054:	31510000 	cmpcc	r1, r0
40001058:	31a01201 	movcc	r1, r1, lsl #4
4000105c:	31a03203 	movcc	r3, r3, lsl #4
40001060:	3afffffa 	bcc	40001050 <__udivsi3+0x2c>
40001064:	e3510102 	cmp	r1, #-2147483648	; 0x80000000
40001068:	31510000 	cmpcc	r1, r0
4000106c:	31a01081 	movcc	r1, r1, lsl #1
40001070:	31a03083 	movcc	r3, r3, lsl #1
40001074:	3afffffa 	bcc	40001064 <__udivsi3+0x40>
40001078:	e3a02000 	mov	r2, #0	; 0x0
4000107c:	e1500001 	cmp	r0, r1
40001080:	20400001 	subcs	r0, r0, r1
40001084:	21822003 	orrcs	r2, r2, r3
40001088:	e15000a1 	cmp	r0, r1, lsr #1
4000108c:	204000a1 	subcs	r0, r0, r1, lsr #1
40001090:	218220a3 	orrcs	r2, r2, r3, lsr #1
40001094:	e1500121 	cmp	r0, r1, lsr #2
40001098:	20400121 	subcs	r0, r0, r1, lsr #2
4000109c:	21822123 	orrcs	r2, r2, r3, lsr #2
400010a0:	e15001a1 	cmp	r0, r1, lsr #3
400010a4:	204001a1 	subcs	r0, r0, r1, lsr #3
400010a8:	218221a3 	orrcs	r2, r2, r3, lsr #3
400010ac:	e3500000 	cmp	r0, #0	; 0x0
400010b0:	11b03223 	movnes	r3, r3, lsr #4
400010b4:	11a01221 	movne	r1, r1, lsr #4
400010b8:	1affffef 	bne	4000107c <__udivsi3+0x58>
400010bc:	e1a00002 	mov	r0, r2
400010c0:	e12fff1e 	bx	lr
400010c4:	03a00001 	moveq	r0, #1	; 0x1
400010c8:	13a00000 	movne	r0, #0	; 0x0
400010cc:	e12fff1e 	bx	lr
400010d0:	e3510801 	cmp	r1, #65536	; 0x10000
400010d4:	21a01821 	movcs	r1, r1, lsr #16
400010d8:	23a02010 	movcs	r2, #16	; 0x10
400010dc:	33a02000 	movcc	r2, #0	; 0x0
400010e0:	e3510c01 	cmp	r1, #256	; 0x100
400010e4:	21a01421 	movcs	r1, r1, lsr #8
400010e8:	22822008 	addcs	r2, r2, #8	; 0x8
400010ec:	e3510010 	cmp	r1, #16	; 0x10
400010f0:	21a01221 	movcs	r1, r1, lsr #4
400010f4:	22822004 	addcs	r2, r2, #4	; 0x4
400010f8:	e3510004 	cmp	r1, #4	; 0x4
400010fc:	82822003 	addhi	r2, r2, #3	; 0x3
40001100:	908220a1 	addls	r2, r2, r1, lsr #1
40001104:	e1a00230 	mov	r0, r0, lsr r2
40001108:	e12fff1e 	bx	lr
4000110c:	e52de004 	str	lr, [sp, #-4]!
40001110:	eb000034 	bl	400011e8 <__div0>
40001114:	e3a00000 	mov	r0, #0	; 0x0
40001118:	e49df004 	ldr	pc, [sp], #4
400011e8 <__div0>:
400011e8:	e12fff1e 	bx	lr
-Mike.
> Hi,
> on the LPC2214
>   a=b/c;
> target, the code
> i step in to the
> __divsi3 from the
> libgcc library.
> return from the
> from the stack
> would be
>   Dean
Do you Yahoo!?
RE: [lpc2000] Division function
2004-11-02 by Dean greaves
Hi Michael,
            I wrote a small application this morning with just the divide
routine in it.  When I stepped through the assembly, I noticed that most of
the function is actually missing ???  It does n't look like what you have at
all.  I'm afraid I'm a bit of a rookie at this, I would be grateful for any
help
Please find attached my ELF file
Cheers and all the best
 Dean
  _____
Sent: 01 November 2004 17:31
To: lpc2000@yahoogroups.com
Subject: Re: [lpc2000] Division function
source:
      return b/c;
      a=test(b,c);
from the elf image:
40000278 <test>:
pc}
<.text+0x1c4>
400011e8 <__div0>:
-Mike.
> Hi,
> on the LPC2214
>   a=b/c;
> target, the code
> i step in to the
> __divsi3 from the
> libgcc library.
> return from the
> from the stack
> would be
>   Dean
Do you Yahoo!?
Yahoo! Groups Sponsor
<http://us.ard.yahoo.com/SIG=12922u7mr/M=281955.5530326.6602771.3001176/D=gr
oups/S=1706554205:HM/EXP=1099416732/A=2343726/R=0/SIG=12im15sga/*http:/clk.a
tdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1099330332354262>
oups/S=1706554205:HM/EXP=1099416732/A=2343726/R=1/SIG=12im15sga/*http:/clk.a
Get unlimited calls to
U.S./Canada
<http://view.atdmt.com/VON/view/yhxxxvon01900091von/direct/01/&time=10993303
32354262>
<http://us.adserver.yahoo.com/l?M=281955.5530326.6602771.3001176/D=groups/S=
:HM/A=2343726/rand=401492818>
  _____
Yahoo! Groups Links
*	To visit your group on the web, go to:
http://groups.yahoo.com/group/lpc2000/
*	To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/>  Terms of Service.
2004-11-03 by Michael Anburaj
Hi Dean,
--- Dean greaves <dgreaves@...> wrote:
> Hi Michael,
This could happen is a typical case like this:
       //a=test(b,c);
       a = b/c;
 %d\n\n",a,b,c);
In the above code, the (high optimization) compiler
would know that the values in \ufffdb\ufffd & \ufffdc\ufffd are fixed,
hence it would optimize it away & load the value 100
(result of 1000/10) directly to \ufffda\ufffd. Due to this you
wont see a call made to __udivsi3. Because of this I
purposefully added a subroutine to do the division.
>  It does n't
> help
No elf file attachment on this email.
-Mike.
Do you Yahoo!?
Check out the new Yahoo! Front Page.
www.yahoo.com
