At 07:20 PM 11/4/04 +0000, you wrote:
>I'm using GCC 3.4.1 in linux.
>I used de crt0.s and lpc2119.ld of the newlib_lpc but when compiling
>doesn't find lnewlib-lpc. This line is in the file lpc2119.ld:
Where did you place libnewlib-lpc.a? It has to be on your library search
path. In any case it's not an issue with the startup code.
Robert
" 'Freedom' has no meaning of itself. There are always restrictions,
be they legal, genetic, or physical. If you don't believe me, try to
chew a radio signal. "
Kelvin Throop, III
