Lpc2000
LPC2194 & LPC2294 JTAG ports
2004-11-15 by gregdeuerling
I'm trying to work out a problem I'm having programming a LPC2194.
I've posted a question on this already here.  See:
http://groups.yahoo.com/group/lpc2000/message/4049
I was looking in the LPC22194 & LPC2294 datasheets and I saw that
the JTAG pins (P1.26-P1.31) PINSEL register was set to P1.26/RTCK at
reset.  The LPC2194 datasheet says the JTAG's PINSEL register is set
to '0' on reset.
Does the JTAG PINSEL register on the LPC2194 need to be set to '1'
for me to program the LPC2194 via JTAG?
The datasheet says the PINSEL is set to '0' at reset, this seems
wrong to me.  Seems it should be the same as the LPC2294.  That way
it always comes up with the debug port enabled.
I was setting the PINSE2 register to 0x00000000 after my program was
up and running because I need to use some of the TRACESYNC pins as
IO.  If I put in a new LPC2194, take out the setting PINSEL2 to
0x0000000, will the JTAG work?  I'll try this later and see if it
works.  I just hate to pull any more LPC2194's off of the PCB...
Re: [lpc2000] LPC2194 & LPC2294 JTAG ports
2004-11-15 by Robert Wood
If it's the same as the 2294 (which seems likely), you have remember that the
processor looks at the state of pin P1.26 (which has to be low) on reset to
go into JTAG mode. Also, the datasheet says you should do a read/modify/write
on the PINSEL register.
It took me absolutely ages to get my head round this!
This is what I did for the 2294, which works for me! I'm sure you'll have to
modify slightly differently for 2194. (In fact checking the datasheet it
looks like bits 2 and 3 are the only relevant ones for you).
// Now PINSEL2 which configures debug lines and address and data lines
	temp = PINSEL2;
	temp |= 0x0F814920;
	temp &= ~0x08;			  // Take it out of trace mode...
	PINSEL2 = temp;
For me, the thing that finally got it working was the line:
You must remember that you *only* want to take it out of trace mode, not out
of debug mode as well
If you write all zeros to PINSEL2 (in fact if you write a zero to bit 2,
you'll take it out of JTAG mode. This wasted a lot of my time sussing this
out.
Also, note that the processor looks at the state of P1.20 to see whether it
should use trace mode for P1.25:16.
Hope this helps.
Rob
to '0' on reset.
Yahoo! Groups Links
2294 CAN Interrupt Vectors
2004-11-16 by Robert Wood
Hi folks,
Can anyone shed any light on the interrupt vectors for the 2294? (I suspect
this question would be valid for all devices with CAN on board actually).
The datasheet, to me, indicates that:
CAN1 and CAN2: 2x(Tx int, Rx int) are assigned to VIC channels 20-23 and
CAN3 and CAN4: 2x(Tx int, Rx int) are assigned to VIC  channels 24-27.
I would have thought that means CAN1 Tx interrupt is on channel 20, its Rx
interrupt is on channel 21; channel 2 Tx interrupt is channel 22 and so on.
So, I set that up and got no interrupts. (CAN was definitely working because
polling the appropriate bit showed messages were received.) Looking at some
of the example files posted on the Yahoo database, the examples seemed to
indicated Channel 1's Rx VIC channel is 26. So, I changed the appropriate
values and found the interrupt worked!
Is the datasheet just wrong (I can't see anything in the errata sheet) or am I
just reading it [the datasheet] incorrectly?
Rob
Re: 2294 CAN Interrupt Vectors
2004-11-16 by mahlerweb
maybe you have an old Datasheet. I use one from May 03,2004 it tells
me:
VIC-Channel 20 CAN1 Tx
VIC-Channel 21 CAN2 Tx
VIC-Channel 22 CAN3 Tx (LPC2194/2292/2294 only, otherwise Reserved)
VIC-Channel 23 CAN4 Tx (LPC2194/2292/2294 only, otherwise Reserved)
VIC-Channel 24-25 Reserved
VIC-Channel 26 CAN1 Rx
VIC-Channel 27 CAN2 Rx
VIC-Channel 28 CAN3 Rx (LPC2194/2292/2294 only, otherwise Reserved)
VIC-Channel 29 CAN4 Rx (LPC2194/2292/2294 only, otherwise Reserved)
VIC-Channel30-31 Reserved
....and it seems to work.
Peter
--- In lpc2000@yahoogroups.com, Robert Wood <robert.wood@a...> wrote:
> Hi folks,
suspect
actually).
23 and
27.
its Rx
and so on.
working because
at some
seemed to
appropriate
sheet) or am I
> Cheers,
> Rob
