Lpc2000
read with SPI
read with SPI
2004-11-25 by dasbento@aeiou.pt
Hello,
I'm using SPI to read data of ADS7807U. My problem is not get to read
the last bit, i.e, bit0. How does the SCK work?
Anybody already work with this and can I help me???
Thanks
      Domingos
IOCLR0 |= SSEL0; //select AD
IOCLR0 |= AD_RC; //(R/C = 0)
delay(2); //wait 50ns
IOSET0 |= SSEL0;
IOSET0 |= AD_RC;
while(!(IOPIN1 & busy_x)){} //wait for busy is 1
for(i=0;i<2;i++){
SPI0_SPDR = 0x10;
while(!(SPI0_SPSR & SPIF)){} //wait that transmit
if(i==0){
gyro_x = SPI0_SPDR; //save the 8 most significant bits
gyro_x = (gyro_x << 8);
}else{
gyro_x += SPI0_SPDR;
IOSET0 |= SSEL0; //deselect AD
_________________________________________________________
CEAC Cursos de forma\ufffd\ufffdo profissional - pe\ufffda informa\ufffd\ufffdes aqui.:
http://ceac.online.pt/
Re: read with SPI
2004-11-26 by mahlerweb
I don't know about ADS7808, but i have done some work with MAX1271
and ADS8344, i think it similar.
I think you  started sampling every time by writing 0x10 to SPI,
so you got always only the high byte of conversion.
Try it like this :
 SPI0_SPDR = 0x10; // assumed this statement starts the sampling
 SPI0_SPDR = 0x0;  // do not start sampling anymore
regards
Peter
--- In lpc2000@yahoogroups.com, dasbento@a... wrote:
> Hello,
> Thanks
>       Domingos
> IOSET0 |= SSEL0;
> IOSET0 |= AD_RC;
> for(i=0;i<2;i++){
> SPI0_SPDR = 0x10;
> if(i==0){
> }else{
> CEAC Cursos de formação profissional - peça informações aqui.:
Re: [lpc2000] read with SPI
2004-11-26 by FabioDB
Il giorno gio, 25-11-2004 alle 20:59 +0000, dasbento@... ha
scritto:
> Hello,
Have you tryed to change phase and polarity (CPOL and CPHA bits of SPI
Control Register)?
FabioDB <fabiodib@...>
Altraqua
Re: read with SPI
2004-11-26 by Gus
if your data is shifted by one bit that means you have the clock
setup wrong. The easiest way is to scope CLK and SDO while you are
sending 0x55 and then compare what you see to how the bus should be
for ADS7807.
Acoording to how you setup the SCK (in LPCxxx registers) data will
be shifted in/out on rising/falling edge on the SCK and you can
setup SCK to be idle low or high.
Gus
> Hello,
read
> Thanks
>       Domingos
> IOSET0 |= SSEL0;
> IOSET0 |= AD_RC;
> for(i=0;i<2;i++){
> SPI0_SPDR = 0x10;
> if(i==0){
> }else{
Re: read with SPI
2004-11-26 by domingos_bento
Hello,
yes I tryed to change phase and polarity, but continue same.
Another thing that happen is that AD to give the double of the scale.
In the datasheet with 0V input would have in hex 0000, midscale (2.5V)
 should have 8000 and to 4.999924V should have FFFF. The results that
I 'm obtain are: 0V input has 0000, 2.5V has FFFF and 4.999924V has FFFE.
thanks
      Domingos
--- In lpc2000@yahoogroups.com, FabioDB <fabiodib@e...> wrote:
> Il giorno gio, 25-11-2004 alle 20:59 +0000, dasbento@a... ha
> scritto:
> > Hello,
> Control Register)?
> Altraqua
Re: read with SPI
2004-11-28 by Richard
Analog supply pins hooked up correctly?
--- In lpc2000@yahoogroups.com, "domingos_bento" <dasbento@a...>
wrote:
> Hello,
scale.
(2.5V)
that
has FFFE.
> thanks
>       Domingos
> > scritto:
> > > Hello,
to read
of SPI
> > Control Register)?
> > Altraqua
Re: read with SPI
2004-11-28 by domingos_bento
Hello,
I have analog supply pins hooked up correctly!!!
One the problem is the following:
the data are not read in the first rising edge. I already put CPHA=0
and CPHA=1 and the result is always the same, read ever SCK falling edge.
Anybody already have this problem??
Thanks
      Domingos
> wrote:
> > Hello,
> scale.
> (2.5V)
> that
> has FFFE.
> > thanks
> >       Domingos
> > > scritto:
> > > > Hello,
> to read
> of SPI
> > > Control Register)?
> > > Altraqua
Re: read with SPI // Max voltage for ADC is 3.6V!
2004-11-28 by lpc2100_fan
Domingos,
the ADC does not support 5V reference. The max. voltage supported is
3.6V.  There is a good chance your device is gone for good.
Bob
> wrote:
> > Hello,
> scale.
> (2.5V)
> that
> has FFFE.
> > thanks
> >       Domingos
> > > scritto:
> > > > Hello,
> to read
> of SPI
> > > Control Register)?
> > > Altraqua
