Lpc2000
Partial Flash Programming (ctd)
2004-12-08 by Leighton Rowe
Concerning Philips Apps' post on Partial Flash Programming I
understand lpc flash memory can be updated 128 bits (minimum) at a
time, and that a each 4K area can be written 16 times (max).
(http://groups.yahoo.com/group/lpc2000/message/2681)
However, I'm currently having trouble updating 128-bit (quadword
aligned) locations in flash memory. The first write always
show up OK (as long as the location has all 1's), but on the 2nd
write (on the same location) results in some bit(s) not displaying
correctly.
Is it possible for me to re-write a 128-bit (quadword aligned) flash
locations? Or must I erase the flash location first? I can do the
second question, but I'm a little confused about how often flash
bits can change without an erase.
best regards,
Leighton
Re: [lpc2000] Partial Flash Programming (ctd)
2004-12-08 by Robert Adsett
>correctly.
As I read that each 128 bit section can only be written once since a
rewrite to change any bits would also change the ECC and since in that case
some of the ECC bits are very likely to need to change back to a 1 state
you are rather out of luck.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
2004-12-09 by onestone
Flash bits can only be written to '0'. They erase to a '1' state.
Therefore unless you are only changing a couple of bits to '0' you MUST
erase flash everytime before reprogramming it.
Al
> correctly.
> best regards,
> Leighton
> Yahoo! Groups Sponsor
> <http://us.ard.yahoo.com/SIG=129krqpo6/M=324847.5707095.6763799.3001176/D=groups/S=1706554205:HM/EXP=1102615194/A=2343726/R=0/SIG=12ibhs9he/*http://clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1102528794344024>
> Get unlimited calls to
> U.S./Canada
> <http://us.ard.yahoo.com/SIG=129krqpo6/M=324847.5707095.6763799.3001176/D=groups/S=1706554205:HM/EXP=1102615194/A=2343726/R=1/SIG=12ibhs9he/*http://clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1102528794344024>
>     * To visit your group on the web, go to:
>     * To unsubscribe from this group, send an email to:
>       lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
Re: Partial Flash Programming (ctd)
2004-12-09 by philips_apps
Hi Al,
even changing some bits from 1 to 0 would generate a wrong reading.
The LPC2000 devices have an error correction  ECC mechanism build in.
 This is part of the flash and will be written the first time (after
erasing) the block of 128-bits is programmed. Any changes thereafter
will result in reading garbage because the ECC mechanism will try to
correct anything changed after the initial write.
The idea was to write one 128-bit block after the other, NOT writing
the same 128-bit block several times. This is possible 16 times within
a 4k block. So 16 writes to 16 different sections of 128-bit each
within a 4k block, then erase the 4k block.
Hopefully this clarifies this issue a little more.
> Al
> > correctly.
> > best regards,
> > Leighton
> > U.S./Canada
> > Yahoo! Groups Links
Re: [lpc2000] Re: Partial Flash Programming (ctd)
Bugger! that totally screws up the filing system I use for flash
database management, and probably the main application I have in mind
for this part. My response was purely a generic one related to flash, as
I've not yet got my hands on any LPC silicon.
philips_apps wrote:
> Hi Al,
>  > Al
>  > > correctly.
>  > > best regards,
>  > > Leighton
> <http://us.ard.yahoo.com/SIG=129krqpo6/M=324847.5707095.6763799.3001176/D=groups/S=1706554205:HM/EXP=1102615194/A=2343726/R=0/SIG=12ibhs9he/*http://clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1102528794344024>>
>  > > U.S./Canada
> <http://us.ard.yahoo.com/SIG=129krqpo6/M=324847.5707095.6763799.3001176/D=groups/S=1706554205:HM/EXP=1102615194/A=2343726/R=1/SIG=12ibhs9he/*http://clk.atdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1102528794344024>>
>  > > Yahoo! Groups Links
> ADVERTISEMENT
> <http://us.ard.yahoo.com/SIG=1291lt2ob/M=295196.4901138.6071305.3001176/D=groups/S=1706554205:HM/EXP=1102663621/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com>
2004-12-09 by Bill Knight
Maybe I was sleeping when this changed so please let me know if
I am wrong.  For the LPC, shouldn't the block size be 512 bytes
and the sector size either 8K or 64K bytes instead of a block size
of 128 bits and a ??? size of 4K???
Confused a bit
-Bill Knight
http://www.theARMPatch.com
On Thu, 09 Dec 2004 07:25:17 -0000, philips_apps wrote:
Hi Al,
2004-12-10 by Bill Knight
Ok, I think my confusion is cleared up a bit.  It came from a mix of
the IAP interface to erase & program the flash and the flash
implementation as descibed by Philips Apps at the end of this message.
In small steps:
1) Data are stored in flash as 128-bit words (plus ecc bits)
2) Because of the ecc bits, each 128-bit word may only be programmed
once without being erased.
3) Multiple 128-bit words are combined in a 4096-bit (512-byte) block.
4) The IAP interface only allows programming of some multiple of
4096-bit (512-byte) blocks (1-512, 2-1024, 8-4096, 16-8192).
Therefore, programming any unprogrammed 128-bit words (16-byte) first
requires copying the 512 byte block in which it resides to a RAM
buffer, adding the new data to the RAM buffer, then using the IAP to
reprogram the 512 byte block.  Erasing the flash first is not required
as long as the new data does not overlay a previously programmed
128-bit word.
5) While a 4096-bit block could potentially be erased, the IAP
interface combines a number of them into 8K/64K sectors and allows
only sectors to be erased.
PLEASE let me know if this is accurate and correct me if it is in
error.
Thanks
-Bill Knight
<snip>
Hi Al,
2004-12-11 by Leighton Rowe
Thank you all for the input. Everything makes sense to me.
I guess the main challenge now to use appropriately sized RAM buffers during IAP calls whenever I'm updating the firmware sectors...without corrupting critical pieces of code (vector table, IAP programmer, etc.)
Leighton
In small steps:
128-bit word.
error.
Thanks
-Bill Knight
<snip>
Hi Al,
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
Do you Yahoo!?
 Meet the all-new My Yahoo! � Try it today!
2004-12-11 by philips_apps
Hi Bill,
thanks for writing it more clearly than I did. Yes you got it. Don't
forget the rule of max 16 writes to a 4k block. Means you can not
write the whole 4k before erasing it again.
Robert
> In small steps:
> 128-bit word.
> error.
> Thanks
> -Bill Knight
> <snip>
> Hi Al,
2004-12-17 by tom_laffey
First off, I now realize that I was missing the ECC interaction in my
earlier post (http://groups.yahoo.com/group/lpc2000/message/4102)
Thanks to Leighton for posting the reference to article 2681, as I
hadn't gone far enough back in the archive to find it.
Since ECC is intended to correct single bit errors, it seems to me
that I might be able to construct multi-bit changes ("errors") that
will not affect the computed ECC value.  Thus the 4-byte word I use
to track my image state might potentially have several usable values
that are compatible with the original ECC entry. My sectoring
arrangement requires only 4 states, so I don't need too many patterns
and the 16 writes per row limit is a distant worry.
Trouble is, I don't know how the ECC value is calculated, so I don't
know how to work out bit patterns to use.  There are books available
on the subject, but what I really need to know is how the LPC works.
Philips, can you help with this?
Here's an illustrative example.  Would a simple progression such as
the following work?  E.g., for one particular word in the row
changing, all other values constant:
  0xFFFFFFFF (erased)
  0xFFF0FFF0 (ECC calculated here)
  0xFF00FF00 (compatible ECC?)
  0xF000F000
  0x00000000
Tom
mind
flash, as
> philips_apps wrote:
> > Hi Al,
reading.
in.
(after
thereafter
to
writing
within
state.
you MUST
> >  > Al
(minimum) at a
(quadword
2nd
displaying
> >  > > correctly.
aligned) flash
do the
flash
> >  > > best regards,
> >  > > Leighton
