A/D converter resolution problems
2004-12-10 by shaneprobinson2000
Hello all, I am having some difficulty getting 10 bit resolution out
of the A/d converter on the LPC2129. I have an opamp directly
coupled to the input of the A/D converter, I am running the A/d
clock at less the 4.5 MHZ, and I am only getting 7 or 8 bits.
The code I am using is as follows:
unsigned long AtoD(void)
unsigned long result;
REG(ATOD_ADCR)=0x00000802; //turn the
a/d off with the channel selected
REG(ATOD_ADCR)=0x00200802; //turn the
a/d on with the channel selected
REG(ATOD_ADCR)=0x01200802; //do the a/d
while((!REG(ATOD_ADDR))&BIT31); //wait for it
green_result=(REG(ATOD_ADDR) & 0xFFFF); //read the
result but ignore
conversion again
result=(REG(ATOD_ADDR) & 0xFFFF); //read the result
(result in bits 7-16)
result>>=6; //shift result
over so result is in lower bits
return(result);
I have found that if I don't cycle the power with the correct
channel selected it doesn't change channels. This is covered
somewhat in the errata. Please help!
Shane.
