Lpc2000
SSEL Pin Error
SSEL Pin Error
2004-12-13 by Sridhar gadda
        when you configured SPI interface , Master as �c. In manual its return that "LPCconfigured as SPI master MUST select SSEL functionality on an appropriate pin and have HIGH level on this pin in order to act as a master" (page 170)
if you configure PINSEL0 = 0x00005500 // selects SCK0, MISO, MOSI and SSLE
but how can we generate HIGH on SSLE pin which is  P0.7..........As far as I know you can only generate HIGH on GPIO pins only if they configured as OUTPUT pins.
             My question is how to generate high on SSLE when it is not configured as GPIO pin.
   Any help and suggestions would be appreciated.
 Thanks in advance.
 With regards,
Sridhar
Do You Yahoo!?
http://mail.yahoo.com
Re: [lpc2000] SSEL Pin Error
2004-12-13 by dasbento@aeiou.pt
Hello,
       when you configured as SSEL, you have make pull up a 3.3V for
SPI interface to act as a master, and to choose other pin GPIO for SSEL!!!
          Domingos
Citando Sridhar gadda <sridhargadda@...>:
> Hi,
>         when you configured SPI interface , Master as \ufffdc. In manual its
> r> eturn that "LPCconfigured as SPI master MUST select SSEL
functionality on
> a> n appropriate pin and have HIGH level on this pin in order to act
as a
> mast> er" (page 170)
> SSL> E
far as
configured as
> O> UTPUT pins.
> con> figured as GPIO pin.
>  Thanks in advance.
>  With regards,
> Sridhar
> Do You Yahoo!?
_________________________________________________________
CEAC Cursos de forma\ufffd\ufffdo profissional - pe\ufffda informa\ufffd\ufffdes aqui.:
http://ceac.online.pt/
Does that mean I should give 3.3v at pin SSEL ?
could you explian your sencntence "you have make pull up a 3.3V for
SPI interface to act as a master, and to choose other pin GPIO for SSEL!!! " .........why sould I choose other GPIO as SSLE ???
regards
Sridhar
dasbento@... wrote:
Hello,
Domingos
Citando Sridhar gadda :
> Hi,
functionality on
as a
> SSL> E
far as
configured as
> O> UTPUT pins.
> Thanks in advance.
> With regards,
> Sridhar
> Do You Yahoo!?
CEAC Cursos de forma��o profissional - pe�a informa��es aqui.:
Yahoo! Groups Links
Do you Yahoo!?
 Meet the all-new My Yahoo! � Try it today!
Re: SSEL Pin Error
2004-12-13 by haack0815
Hi Sridhar,
if the SPI is configured as master the SSEL pin is an input and must
be held high (pullup)to opperate.
You must chose another I/O pin for the chip select signal of the slave
device.
Andreas Haack
> regards
> Sridhar
> dasbento@a... wrote:
> Hello,
SSEL!!!
> Domingos
> > Hi,
> > when you configured SPI interface , Master as µc. In manual its
> functionality on
> as a
> > SSL> E
> far as
> configured as
> > O> UTPUT pins.
> > Thanks in advance.
> > With regards,
> > Sridhar
> > Do You Yahoo!?
> > Yahoo! Groups Links
> CEAC Cursos de formação profissional - peça informações aqui.:
> Do you Yahoo!?
>  Meet the all-new My Yahoo! – Try it today!
Re: [lpc2000] Re: SSEL Pin Error
            So,  SCK0 signal we should generate through software control or �c generates on its own when you set register S0CPCCR ???  ( when �C as master )
haack0815 <lpc_arm@...> wrote:
Hi Sridhar,
device.
Andreas Haack
> regards
> Sridhar
> Hello,
SSEL!!!
> Domingos
> > Hi,
> functionality on
> as a
> > SSL> E
> far as
> configured as
> > O> UTPUT pins.
> > Thanks in advance.
> > With regards,
> > Sridhar
> > Do You Yahoo!?
> > Yahoo! Groups Links
> Do you Yahoo!?
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
   To visit your group on the web, go to:
http://groups.yahoo.com/group/lpc2000/
Do you Yahoo!?
 Send holiday email and support a worthy cause. Do good.
Re: SSEL Pin Error
Hi Sridhar,
in master mode SCK , MOSI are outputs and MISO is an input.
SCK is generated by the uC, the frequenc are set by using the SxSPCCR
register.
Andreas Haack--- In lpc2000@yahoogroups.com, Sridhar gadda
> Hi,
control or µc generates on its own when you set register S0CPCCR ???
( when µC as master )
>  Regards
> haack0815 <lpc_arm@s...> wrote:
> Hi Sridhar,
> device.
> Andreas Haack
> > regards
> > Sridhar
> > Hello,
> SSEL!!!
> > Domingos
> > > Hi,
> > functionality on
> > as a
MOSI and
> > > SSL> E
> > far as
> > configured as
> > > O> UTPUT pins.
> > > Thanks in advance.
> > > With regards,
> > > Sridhar
> > > Do You Yahoo!?
> > > Yahoo! Groups Links
> > Yahoo! Groups Links
> > Do you Yahoo!?
> Do you Yahoo!?
