VIC not taking Jump to Interrupt ISR
2004-12-13 by sig5534
This is my first ARM7 project, so I am sure I must be missing something really simple, but I sure can't find what it is. I'm using JetJTAG debugger and the IAR compiler, and a bit of MakeApp stuff. I didn't trust what MakeApp was doing so I put my own manual VIC init calls in after their init. But same problem persists. I'm trying to get the TIMER-0 INT to fire. The counter is setup and running, and it looks like all of the INT flags go off in the T0 and VIC as they should, but yet it never jumps into the ISR routine. I have TIMER0(VIC-CH4) set to go to IRQ slot-0. Here's what the T0 and VIC registers look like after it runs: T0IR 0x0001 (Int Flag Tripped, yes?) T0TCR 0x0001 (Counter enabled) VICFIQStatus 0x0000 VICIRQStatus 0x0010 (Int flag tripped for T0, yes?) VICRawIntr 0x2018 VICIntSelect 0x0020 (I have T1 set to go to FIQ later) VICIntEnable 0x0070 VICSoftInt 0x0000 VICProtection 0x0000 VICDefVectAddr 0x0948 VICVectAddr 0x095C VICVectAddr0 0x095C ( correct ISR adr) VICVectCntl0 0x0024 (T0 is VIC-CH4, and Enabled) If I understand this, the INT flag in VICIRQStatus is tripped correctly. So why is it not taking the jump to the ISR adr? Help! I'm stuck. Thanks, Chris.
