Bit timing on CAN
2004-12-15 by albin_martinsson
Hi Can someone please explain how to calculate the bit timings for the CANbus? eg. how to calc the value that should be written in the register CANBTR. Im having the core run at 90Mhz (im using an ext osc @ 12 MHz) and VPB-clock is also 60 Mhz. I want to have a CANbus that operates at 125Kbps/250Kbps and 500 Kbps Can someone pls help me with this B.R /Fredrik Martinsson, V-Teknik, Sweden
