Lpc2000
Problems with New version of IAR Kickstart board
2004-12-17 by Richard
I have used an older version of the IAR Kickstart board with no
problems.  I setup a newer version of this board (identified by the
larger buttons) for a colleague and am having problems with ISP.  It
will always read the part ID but fails when any other operation is
attemped.  I have tried it on several computer/serial ports.  I have
tried various baud rates.  The older board works fine.
The old board appears to be four layer while the newer one has two.
I plan to replace the ST rs232 shifter with a MAX3232 to see if this
helps.
Rich
Re: Problems with New version of IAR Kickstart board
2004-12-17 by emailakb
Hi Richard,
I checked ISP on the new IAR board and all ISP commands seem to be
working fine for me.
Just check if JP4,JP7 and JP8 are connected.
Amit
It
have
this
> helps.
> Rich
