Lpc2000
IAR Kickstart Troubles with ARMJTAG ARM LPC21xx JTAG Adapter
2004-12-19 by Markus Meng
Hi all,
I tried to compile and download and debug one of sample application
of the IAR system for the LPC210x Kickstart System.
However I do get the error message:
NT Driver not Found: MAC_MOT.SYS
Is there a simple way to verify that the JTAG connection is up
and running within the IAR system?
Markus
- The machine is a W2K SP4
- The target board is the one from Olimex - without LCD relay etc.
- I did setup to Wiggler on LPT1
Mit freundlichen Gr\ufffdssen
Markus Meng
** Meng Engineering        Telefon    056 222 44 10                   **
** Markus Meng             Natel      079 230 93 86                   **
** Bruggerstr. 21          Telefax    056 222 44 34                   **
** CH-5400 Baden           Email      markus.meng@... **
**                         Web        www.meng-engineering.ch         **
** You cannot create experience. You must undergo it. Albert Camus    **
