Lpc2000
MEMMAP Manipulation
MEMMAP Manipulation
2004-12-20 by Leighton Rowe
Let's say MEMMAP's initially configured as 1 (flash mode), and I
plan todo a complete firmware update using IAPs. If I remapped the
interrupt vectors to RAM (MEMMAP = 2) before overwriting segment 0,
will the original vectors remain preserved in RAM?
Re: MEMMAP Manipulation
2004-12-20 by Karl Olsen
--- In lpc2000@yahoogroups.com, "Leighton Rowe" <leightonsrowe@y...>
Before changing MEMMAP from 1 to 2, you should write whatever you
want as interrupt vectors to RAM (0x4000_0000 - 0x4000_003F).
Changing MEMMAP doesn't by itself copy anything from flash to RAM.
Relocating the interrupt vectors to RAM is only necessary if you need
to handle interrupts during the flash writing.  In that case, you
should also copy the interrupt handlers themselves to RAM.  It might
be easier to just disable all interrupts and use polled I/O.  When
updating the whole flash, you of course have to copy the firmware
updating code to RAM as well.
Karl Olsen
Makes much more sense now. I'm able to get the RAM Mode working.
Thanks.
need
might
I'd rather go with updating segments (not containing the original
program code) with the new program (int handlers included). That way
flash functions won't have to be copied and executed in RAM. I hope
this suggestion isn't too hard to pull off.
Leighton
