Lpc2000
firmware update
firmware update
2004-12-21 by sifiland
I would like to write the firmware update software in C.
Someone already so which made?
Who has a sample program?
thanks
Re: firmware update
2004-12-22 by dimaissaev
--- In lpc2000@yahoogroups.com, "sifiland" <sifiland@y...> wrote:
> Hi,
> thanks
Did you mean a boot-load update of you have a existing device and you
will add some new functions?
Re: firmware update
2004-12-22 by sifiland
> > Hi,
> > thanks
you
I would like to write a routine, which takes over the task of more
bootloader.  That is, I do not want to use more bootloader for the
flashen at all.
Re: firmware update
2004-12-22 by lpc2100_fan
although it is possible to erase the bootloader, most likely your
microcontroller will be useless after you did so, not recommended, it
is there to support programming.
Write your own bootloader just by having it start at address 0. After
the basic initialization of the micro, it will start execution right
there at address 0.
Cheers, Bob
> > > Hi,
> > > thanks
> you
> flashen at all.
