Lpc2000
Configuring the Timer 0
2004-12-21 by acetoel
Hello...
I'm configurin Timer 0... My Clock is a 10Mhz Crystal PLLed to 60Mhz
for the CCLK and the PCLK.
If I set the P0PR (prescaler register) to 0xEA60 (decimal 60000), then
when I start the Timer 0, will I have an increment on T0TC (Timer
Counter) each 60000 cycles of clock? or what's more easy to
understand... will T0TC increment in one each 1ms?
My idea is to make a short rutine that start the timer, and stop it
when 1mS has passed...
Thanks
Ezequiel
Re: Configuring the Timer 0
2004-12-22 by kaiandxiulpc2000
I didn't use the pre-scale register, but the main TC.  I think you
need to decrement your value by 1 to 0xEA5F.  The way the timer
works, the value 0 is one tick of the pclk, 1 is the 2nd tick, etc..
59999 is your 60,000th tick.  Look in the User Manual figures and you
will see that.
--- In lpc2000@yahoogroups.com, "acetoel" <acetoel@y...> wrote:
> Hello...
then
> Thanks
> Ezequiel
2004-12-23 by dimaissaev
> Hello...
then
> Thanks
> Ezequiel
Yes. And don't forget about VPB bus clock
Re: [lpc2000] Configuring the Timer 0
2004-12-23 by Robert Adsett
Remember a counter only has a 1 count accuracy at best.  If you want to
time a single ms wait your count should be much faster (10x faster will
give you 10% accuracy).  That's one reason the timer in the newlib-lpc
support runs as fast as it does.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
