Lpc2000
EXTMODE/EXTPOLAR & VPBDIV
2004-12-31 by Kerem Or
Dear Philips Apps people,
LPC2214 fails to write 0x0d to EXTMODE register even when VPBDIV=0
as advised in the device errata. The EXTMODE register prior to write
was 0x0f and gets 0x00 just after attempting to set to 0x0d.
What happens is in conflict with the workaround suggested in the
device errata.
Please advise...
Device marking
LPC2214FBD144
CD0931 05
TS0432A
Kerem Or,
SYS Inc.
2005-01-19 by philips_apps
Hi Kerem,
This is actually a bug which is related to the EXTINT.1 bug (present
in the Errata sheet).
Problem: Incorrect setting of EXTMODE and/or EXTPOLAR register while
trying to set them to desired value.
For instance, trying to set EXTMODE to 0x1 or 0xd would result in
EXTMODE to be set to 0x0 instead. To avoid this problem, while
writing to EXTMODE and/or EXTPOLAR the following steps have to be
carried out.
Workaround:
Since this issue is related to the EXTINT.1 Errata, the same
workaround applies with an additional step.
Before writing to the EXTMODE and EXTPOLAR registers,
1> Write 0x0 to VPBDIV
2> Then write the desired value to EXTMODE or EXTPOLAR register.
3> Then write the same value to VPBDIV ( additional step)
4> Restore the VPBDIV to the previously saved value or simply write
to the register again with the desired value.
Note:
While testing this in a debugger enviornment, please dont single-step
through these steps. A breakpoint could  be placed after Step 4 and
you would see the EXTMODE and EXTPOLAR registers reflecting the
correct values.
The Errata sheet for these devices will be updated soon. This bug is
not present in the LPC213x.
Thanks
Philips_apps
write
> device errata.
> Please advise...
> Device marking
> LPC2214FBD144
> CD0931 05
> TS0432A
> Kerem Or,
> SYS Inc.
Re: [lpc2000] EXTMODE/EXTPOLAR & VPBDIV
2005-01-19 by Bruce Paterson
Question below:
philips_apps wrote:
> Hi Kerem,
If I want to program both EXTMODE and EXTPOLAR, do I have to do this
in two passes: old=VPBDIV, VPBDIV=0, EXTMODE=n, VPBDIV=n, VPBDIV=0,
EXTPOLAR=y, VPBDIV=y, VPCDIV=old ?
(or can fewer steps be used somehow ?)
Bruce
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom
they are addressed. If you have received this email in error please
notify the system manager.
     /\\\/\\\/\\\    /   /      Bruce Paterson
    /  \\\ \\\ \\\  /   /    Senior Design Engineer
   /   /\\\/\\\/\\\/   /   8 Anzed Court, Mulgrave, Vic, 3170
  /   /  \\\ \\\ \\\  /  PO Box 4112, Mulgrave, Vic, 3170, Australia
/   /    \\\/\\\ \\\/   Ph: +61 3 8561 4232   Fax: +61 3 9560 9055
       Tele-IP Ltd.      Email: bruce@...    Icq: #32015991
                         WWW:   http://www.tele-ip.com       VK3TJN
Re: EXTMODE/EXTPOLAR & VPBDIV
Hi Bruce,
There is no shorter way that this could be done. Also, please note,
while reading the VPBDIV, it should be read twice. So you would want
to do the following steps.
old= VPBDIV;
old= VPBDIV;
Thanks
Philips apps
--- In lpc2000@yahoogroups.com, Bruce Paterson <bruce@t...> wrote:
> Question below:
> philips_apps wrote:
> > Hi Kerem,
(present
while
> Cheers,
> Bruce
>        Tele-IP Ltd.      Email: bruce@t...    Icq: #32015991
2005-03-04 by Kerem Or
Dear Sir,
    VPBDIV=0;
    EXTMODE=0x0d;
    VPBDIV=0;
    VPBDIV=VPB_DIV_VAL;
I have placed a breakpoint after the last line and EXTMODE still reads 0. I
guess I am unable to make this work
Can you advise why the suggested workaround did not help?
Best regards,
Kerem
To: <lpc2000@yahoogroups.com>
Sent: Wednesday, January 19, 2005 2:25 AM
Subject: [lpc2000] EXTMODE/EXTPOLAR & VPBDIV
> Hi Kerem,
> carried out.
> Workaround:
> Note:
> correct values.
> Thanks
> Philips_apps
> write
>> device errata.
>> Please advise...
>> Device marking
>> LPC2214FBD144
>> CD0931 05
>> TS0432A
>> Kerem Or,
>> SYS Inc.
