Lpc2000
Vector Checksum not generated in .hex file
2005-01-07 by Leighton Rowe
Is it true that Phillips ISP does the checksum calculation before
programming the vector code into flash?
I notice the .hex files that I'm making (using IAR's software)
doesn't contain the calculated checksum (0x14)for the vector code.
It's usually filled with 0's (without the fill option).
Is there's a way for me to generate the vector checksum in the 0x14
space of the hex file?
Re: [lpc2000] Vector Checksum not generated in .hex file
2005-01-07 by Robert Adsett
Yes, as do both the other serial ISP programs I am aware of.
Well, you could read it into Philps SW and have calculate the checksum and
write in back out again.  I think that works anyway.  I'm not sure I see
the point though.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Re: Vector Checksum not generated in .hex file
checksum and
I see
> the point though.
Well the IAP updater that I'm working on reads the hex file and
reprograms the lpc with the new code.
If u look at the hex file example...
:1000000018F09FE5FEFFFFEAFEFFFFEAFEFFFFEAB2
:10001000FEFFFFEAFFFFFFFFF0FF1FE500F09FE597 <---0x0014 is "FFFFFFFF"
:10002000A48C000028950000FFFFFFFFFFFFFFFFEB
...my concern is that the vector checksum in the hex file isn't
generated. I'd rather have the IAP updater do a vector check (before
programming the reset block) instead of just calculating & storing
the vector sum. The latter seems to assume that there are valid jump
commands in the reset block.
Leighton
Re: [lpc2000] Re: Vector Checksum not generated in .hex file
>checksum and
>I see
> > the point though.
OK, but a valid checksum won't be any assurance that the jumps are
valid.  That'll just mean that something may have calculated the
checksum.  The tool (whatever its is) that does the checksum calculation
could have been fed an invalid file as easily as the updater.
If you want to only use verified files then I'd think about encapsulating
them with a whole file check (CRC, MD5 or something similarly robust).  You
could even use some sort of cryptographic checksum with your own key so
that it was difficult to forge.
I'm thinking that the validity check (and checksum calculation come to
that) should be done by the download program not the micro (for that
matter, that's the way the ISP programs do it).
Robert
                         Kelvin Throop, III
2005-01-07 by Mark Butcher
Hi Leighton
As you are now aware the Philips ISP generate the check sum during
download. However there may be some more issues here to consider.
1. The checksum is used by the boot to check whether there is user
code in the FLASH. If the check is not good the boot code stays in
ISP mode thus allowing an update. The value must be correct
otherwise the (user) code will never start.
2. The validity of the check sum says nothing about the validity of
the program. A bad program can crash as soon as it starts and the
boot software is stuck. It will always start the bad code and this
will always crash - to get out of this loop the only way is to hold
the ISP pin input low on reset.
3. Also the download of a good software is not fool proof. If the
download is interrupted before it is complete you effectively get
situation 2.
4. An improvement of the Philips ISP loader would be to load the
application coded first and the vector tables with check sum
(validity) as very last job. This would avoid 2 occuring when
interrupting a download in 99,99% of the casees (exception is
interrupting as the vactor table exactly then when it is being
programmed...)
Cheers
Mark Butcher
www.mjbc.ch
PS I have an encoded signature over the user program which is
verified before the application allows itself to start (security
requirement). Important to note is that this technique requires
about 32k of the code space just for this feature - is it worth it
in most applications? Code can be used from OpenSSL project...
--- In lpc2000@yahoogroups.com, "Leighton Rowe" <leightonsrowe@y...>
0x14
2005-01-13 by rob@usbmicro.com
Leighton,
This is what I do.
The vector table for the processor (The first 32 bytes of memory)
normally has branches to the routines. Since routine addresses change
as code is changed, the checksum changes.
I created a table of seven addresses located immediately after the
vector table. These seven addresses are the start addresses for reset
and the interrupts. The branch instructions of the interrupt vector
table were replaced with a load PC instruction pointing to the
appropriate address.
The hex file will then have the checksum. My startup code below:
@ Interrupt vectors
intvect:
        LDR     pc, startaddr
        LDR     pc, undefinstaddr
        LDR     pc, softintaddr
        LDR     pc, preabortaddr
        LDR     pc, dataabortaddr
        .word   0xb8a06f60
        LDR     pc, interruptaddr
        LDR     pc, fastintaddr
startaddr:
        .word   start
undefinstaddr:
        .word   undefined_instruction_routine
softintaddr:
        .word   software_interrupt_routine
preabortaddr:
        .word   prefetch_abort_routine
dataabortaddr:
        .word   data_abort_routine
interruptaddr:
        .word   interrupt_routine
fastintaddr:
        .word   fast_interrupt_routine
@ Start up code
start:
 <code...>
2005-01-13 by Richard
You can load your HEX file in the the flash utility, generate the
checksum (Vector calc button in the flash screen) and save the HEX
file back.
Richard
code.
0x14
> Leighton,
> This is what I do.
change
reset
> @ Interrupt vectors
> intvect:
>         LDR     pc, startaddr
>         LDR     pc, softintaddr
>         .word   0xb8a06f60
>         LDR     pc, fastintaddr
> startaddr:
>         .word   start
> undefinstaddr:
> softintaddr:
> preabortaddr:
> dataabortaddr:
> interruptaddr:
> fastintaddr:
> @ Start up code
> start:
>  <code...>
2005-01-13 by Leighton Rowe
> > intvect:
> >         LDR     pc, startaddr
> >         LDR     pc, softintaddr
> >         .word   0xb8a06f60
> >         LDR     pc, fastintaddr
> > startaddr:
> >         .word   start
> > undefinstaddr:
> > softintaddr:
> > preabortaddr:
> > dataabortaddr:
> > interruptaddr:
> > fastintaddr:
The Hard Coded way...not bad at all.
> file back.
> Richard
That's pretty close to what I'm currently doing before updating the
firmware using IAP calls (not the ISP utility) during code execution.
Both would work for me. Thanks.
Leighton
2005-01-14 by rob@usbmicro.com
>> > intvect:
>> >         LDR     pc, startaddr
>> >         LDR     pc, softintaddr
>> >         .word   0xb8a06f60
>> >         LDR     pc, fastintaddr
>> > startaddr:
>> >         .word   start
>> > undefinstaddr:
>> > softintaddr:
>> > preabortaddr:
>> > dataabortaddr:
>> > interruptaddr:
>> > fastintaddr:
I'm sure that you understand this, but for those that don't, let me
mention that the checksum is done over the first 8 integers (32 bit
integers) of flash memory excluding the area where the checksum is
stored. That is, in the assembly code above, the stuff between the
label "intvect:" and the label "startaddr".
Although the location for start and all of the routines may change as
code is developed, all of those changes happen after the label
"startaddr:" (as resolved by the linker).
The net result is that the first 32 bytes (address 0000 to 001F)
will always contain the same values, and thus the checksum (two's
compliment sum) will also remain the same. The hex file will have
these first two lines:
:10 0000 00 18F09FE5 18F09FE5 18F09FE5 18F09FE5 C0
:10 0010 00 18F09FE5 606FA0B8 14F09FE5 14F09FE5 1D
(I added spaces to make it easier to understand.)
You can see the ".word   0xb8a06f60" in the hex file which is the
two's compliment sum of the other integers. (Note the byte order is
reversed.) 0xb8a06f60 doesn't need to change, even when the routines
move.
So no need for any external program to do the calculation each time
that the source is compiled.
I anticipate using a loader other than the Philips utility, so I
wanted to resolve the checksum calculation without needing to use the
Philips utility. This way the hex file has the checksum.
[Insomnia is no fun...]
-Rob
>> file back.
>> Richard
> Leighton
