Lpc2000
LPC2138
LPC2138
2005-01-13 by gsudershanraj
Hello Guys,
1)Is the JTAG port used for debudding can also be used for
programming the flash for production of LPC2138.
2)WHere can I get the 20pin JTAG port protocol details for interface
connections.
3) where can I get the latest USER MANUAL for ARM processor of
LPC2138, is it same as LPC21XX/22XX.
Sudershan
Re: LPC2138
2005-01-13 by Rick Collins
--- In lpc2000@yahoogroups.com, "gsudershanraj" <gsraj@p...> wrote:
> Hello Guys,
> connections.
Yes, you can program the Flash through the JTAG port, but it won't be
fast and it will be a bit of work to get production quality software
running (meaning "push this button to program").
IIRC, all of the LPC parts come with a serial port boot loader that
should be a bit easier to get running for your needs.  Can you use the
serial port?  If you don't want the RS232 transceiver on your board,
you can use a paddle board for that.  If you don't want the cost of a
connector on the board, you can use a card edge connector or even a
clamp on connector.
RE: [lpc2000] Re: LPC2138
2005-01-13 by Charles R. Grenz
	Which USART is used for ISP programming? I looked in the user manual
and it says it can be done, but nothing about which port on the LPC2138.
Charles
Sent: Thursday, January 13, 2005 12:56 PM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] Re: LPC2138
> Hello Guys,
> connections.
Yes, you can program the Flash through the JTAG port, but it won't be fast
and it will be a bit of work to get production quality software running
IIRC, all of the LPC parts come with a serial port boot loader that should
be a bit easier to get running for your needs.  Can you use the serial port?
If you don't want the RS232 transceiver on your board, you can use a paddle
board for that.  If you don't want the cost of a connector on the board, you
can use a card edge connector or even a clamp on connector.
Yahoo! Groups Links
Re: [lpc2000] Re: LPC2138
2005-01-13 by Robert Adsett
> > Hello Guys,
>clamp on connector.
Martin's LPC21ISP program should be well suited to production use.  Even
without modification it's command line nature should be a help and it could
be easily incorporated into a production test program.  Heck as far as a
paddle board, I've got them to sell ;)  Another connector alternative if
you are worried about room (and JTAG will be worse than serial) is to place
the physical connector on a breakway piece and remove it after
programming.  Reprogramming is more difficult that way of course.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Re: LPC2138
2005-01-13 by gregdeuerling
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@a...>
wrote:
> > > Hello Guys,
won't be
software
that
use the
board,
of a
a
> >clamp on connector.
use.  Even
it could
far as a
alternative if
to place
> Robert
restrictions,
to
>                          Kelvin Throop, III
Martin's LPC21ISP program does not work on any of the LPC21/LPC22
family.  See: http://engelschall.com/~martin/lpc21xx/isp/index.html
I was hoping to use it.  I'll just have to wait till he gets it
going...
I'm using it on the 2106 etc fairly frequently.  There is a note that it
doesn't work on newer members (thanks for pointing that out).  I'll have to
look into this when I get my 2138 running.
Robert
                         Kelvin Throop, III
Re: LPC2138
2005-01-13 by lpc2100_fan
seems to be  alittle misunderstanding here: There is no LPC2000 device
from Philips, all devices are either LPC21xx or LPC22xx. The LPC22xx
are simply external bus versions of the LPC21xx.
Did not use Martin's program yet, used the Philips ISP, but what works
with LPC21xx HAS to work with LPC22xx as well.
Cheers, Bob
--- In lpc2000@yahoogroups.com, "gregdeuerling" <egads@f...> wrote:
--snip--
> use.  Even
> it could
--snip--
                         Kelvin Throop, III
> going...
Re: LPC2138
2005-01-13 by lpcarmed
I'm using Martin's LPC2ISP for LPC2114 boards with no problem, I'm
happy with it. Bootlodaer was 1.63.
--- In lpc2000@yahoogroups.com, "lpc2100_fan" <lpc2100_fan@y...> wrote:
> Hi,
> Cheers, Bob
> --snip--
> > use.  Even
> > it could
> --snip--
>                          Kelvin Throop, III
> > going...
I can also confirm it works with the 2119.  I believe Martin follows this
group, perhaps he can clarify his warning for us?
Robert
                         Kelvin Throop, III
Re: LPC2138
2005-01-14 by lpc2100_fan
just in case you did not find it yet, the latest Users Manual is here
in the Yahoo Group in the "Files" section. Revision from November 2004
Bob
> Hello Guys,
> Cheers,
> Sudershan
Re: LPC2138
2005-01-14 by nutleycottage
CrossWorks for ARM manages to program the LPC2xxx flash via the JTAG
port with a single button click. It can do it at 14Kbytes per second
using a wiggler and 25Kbytes per second using a CrossConnect. We have
customers who have bought CrossWorks just for this feature.
Michael
> > Hello Guys,
> > connections.
> clamp on connector.
2005-01-17 by Anton Erasmus
On 13 Jan 2005 at 19:06, lpc2100_fan wrote:
> Hi,
> Cheers, Bob
There is a problem with differing block sizes on the LPC2292 at least. The
first part programs fine, until it hits the first different sized flash block.
   Anton Erasmus
> --snip--
> > use.  Even
> > it could
> --snip--
>                          Kelvin Throop, III
> > going...
A J Erasmus
2005-01-17 by Robert Adsett
That makes sense.  Does anyone know if any of the 2100 variants have the
same block size issue?  Maybe I should just go look.
Robert
                         Kelvin Throop, III
Re: LPC2138
2005-01-17 by Richard
There are three memory block configurations, the 210x series, the
212x/22xx series, and the 213x series.
Richard
least. The
flash block.
> Robert
>                          Kelvin Throop, III
I'll have to take a look at what I've got.  Maybe I can start taking a stab
at this.
Robert
                         Kelvin Throop, III
Re: LPC2138
2005-01-22 by embest1sale1
Yes, You can program the flash of LPC2138 via JTAG port. Embest flash
programmer can do this. Look detail at:
http://www.embedinfo.com/english/company/news/FP_Philips.asp
> Hello Guys,
interface
> connections.
> Cheers,
> Sudershan
2005-01-22 by Alex Holden
That's the third advert for your product you've sent us in less than an
hour.
------------ Alex Holden - http://www.alexholden.net/ ------------
If it doesn't work, you're not hitting it with a big enough hammer
Re: LPC2138
2005-01-22 by leon_heller
--- In lpc2000@yahoogroups.com, Alex Holden <alex@l...> wrote:
flash
than an
> hour.
I've sent him an email, asking him to stop doing it. He'll get banned
if he does it again.
Leon
Moderator
Re: LPC2138
2005-01-22 by Rick Collins
> flash
> than an
> > hour.
He's already banned in my groups.  I also started receiving direct
emails from them to the email address I use in these groups.
LPC2138
2005-04-18 by sudip nag
Hi Everyone,
I like to start with LPC2138 JTAG programming. Can you provide a link from where I will get the 14 pin and 20 pin JTAG Wiggler Circuits. I find Olimex is not disclosing the ARM-JTAG circuit.
Regards.
Sudip Nag
Yahoo! India Matrimony: Find your life partneronline.
Re: [lpc2000] LPC2138
2005-04-18 by Vitor Cremasco
there is a circuit at download files area of
yahoogroups.
--- sudip nag <sudipnag1@...> wrote:
> Hi Everyone,
> Regards.
> Sudip Nag
> partneronline.
> removed]
Yahoo! Acesso Gr\ufffdtis - Internet r\ufffdpida e gr\ufffdtis.
Instale o discador agora! http://br.acesso.yahoo.com/
Thank you. I got the circuit and try it out.
Sudip
yahoogroups.
> Hi Everyone,
> Regards.
> Sudip Nag
> partneronline.
> removed]
Yahoo! Acesso Grátis - Internet rápida e grátis.
Yahoo! Groups Links
   To visit your group on the web, go to:
http://groups.yahoo.com/group/lpc2000/
Re: LPC2138
2005-04-18 by Owen Mooney
See the files section - Wriggler circuit in ASCII art.
Owen Mooney
Hi Everyone,
Regards.
Sudip Nag
2005-04-20 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Monday, April 18, 2005 3:02 PM
Subject: [lpc2000] LPC2138
> Hi Everyone,
My JTAG (20-pin) interface design is in jtag.zip in the Files area. I've
only used it with the LPC2106.
Leon
Leon Heller, G1HSM
http://www.geocities.com/leon_heller
