Lpc2000
MAX3232 problems?
MAX3232 problems?
2004-01-07 by David Willmore
I finally have one of Leon's lpc210x proto boards assembled.
The problem is the MAX3232 runs warm and seems to be drawing
150mA or so--it varies a bit.
The lpc2106 runs at ambient and has detectable 10MHz on its
clock pins.  Removing the MAX3232 from the board causes it
to use very little current ~10mAh, so I'm assuming the CPU
is okay.
Is there some common failure mode these things experience?
I'm pretty sure there was no reverse voltage, etc.  Could
a poorly connected cap do this?
I *really* want to talk to this thing, but if the serial
interface won't work....
David
Re: [lpc2100] MAX3232 problems?
2004-01-07 by capiman@t-online.de
Hello David,
Do the CAPS have the right polarity ?
Pay attention: Pin 6 is the - side of the CAP, GND this time the '+' side.
Same thing for Pin 2: - side to VCC 3.3 and + side to Pin 2.
But usually when something above is wrong, the CAPS go hops (really, i saw
tantals burning...).
Have you used 3.3V as supply voltage for the MAX and the CAPS ? But i had a
look at Maxim website and MAX3232 can also be driven by 5V. So this is not a
problem.
The RS232 and TTL side is not exchanged ?
Sorry,
      Martin
To: <lpc2100@yahoogroups.com>
Sent: Wednesday, January 07, 2004 10:43 PM
Subject: [lpc2100] MAX3232 problems?
> is okay.
> Cheers,
> David
> To visit your group on the web, go to:
>  http://groups.yahoo.com/group/lpc2100/
> To unsubscribe from this group, send an email to:
>  lpc2100-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to:
>  http://docs.yahoo.com/info/terms/
2004-01-07 by Leon Heller
Sent: Wednesday, January 07, 2004 9:43 PM
> is okay.
It sounds as if the MAX3232 has failed, it shouldn't take anything like that
amount of current and shouldn't be warm. Many years ago I had quite frequent
failures of the earlier version of this type of chip, caused by connecting
the host machine to my board whilst the host was powered up. The current
chips have ESD protection and seem a lot more robust.
Check the voltages on the charge pump capacitors, if they are wrong (IIRC
they should be about +/- 5V and +/- 12V) it won't work. Make sure you
haven't got any shorts. Have you tried a new chip?
Leon
Leon Heller, G1HSM
Email: aqzf13@...
My low-cost Philips LPC210x ARM development system:
http://www.geocities.com/leon_heller/lpc2104.html
Hello, Leon.
Are you talking about the difference between the MAX3232 and MAX3232E kind of
difference?
They are off. They're more like 2.7V and 5.5V and -5.1V.
I'll try a new chip next.  If this were socketed, I could replace it more
easily. ;)
David
Is it also getting hot, when you don't have a serial cable connected ?
TX <-> RX exchanged ?
BTW: using a MAX-232 on my board, it is running for hours, is not even a bit
hot.
Sent: Wednesday, January 07, 2004 11:15 PM
Subject: Re: [lpc2100] MAX3232 problems?
side.
> Used ceramic caps.  Thought they were too small, so I replaced them with
> 4.7uF tants--which I was very sure to follow the data sheet and get the
> polarity right.  So, that's probably not it.
> The datasheet shows the V+ cap going to ground on the - side, but Leon's
> board has it going to Vcc.  That shouldn't make a difference, but it's
> a little difference that I noticed.
saw
> They didn't do that, so one thing went right.  Ever seen a 'lytic go?
It's
> like confetti. :)
had a
not a
> > problem.
> It's running from the 3.3V supply on the board.
> Uhhh, didn't look like it.  Take a look at the board layout on Leon's
website
> for verification?
> Cheers,
> David
Sent: Wednesday, January 07, 2004 10:11 PM
> Hello, Leon.
that
frequent
connecting
of
> difference?
No, I'm talking about the original MAX232, 20 years ago. 8-)
(IIRC
2.7 V is definitely wrong.
Leon
Leon Heller, G1HSM
Email: aqzf13@...
They didn't do that, so one thing went right.  Ever seen a 'lytic go?  It's
like confetti. :)
> problem.
Uhhh, didn't look like it.  Take a look at the board layout on Leon's website
for verification?
David
Sent: Wednesday, January 07, 2004 10:15 PM
side.
Oops! You are right. It could cause a problem with a polarised cap. Try
putting it the other way round.
I'll correct the schematic and fix the problem if I get some more boards
made. I'll modify
any more boards I send out.
100 nF ceramic caps are really all that is needed. The older MAX232 needs 1
uF.
Leon
Leon Heller, G1HSM
Email: aqzf13@...
Even with no cable.  That's how I started. :(
> hot.
That's what it's supposed to be like. :(
David
> made. I'll modify
> uF.
I put in a 100nF chip cap for the problematic V+ cap and put in a new
MAX3232.  No joy.  Same results.  150mA current draw and a warm chip.
Could both of my chips be bad?  I've never had this bad of luck since
I put a chip in backwards.  PICs hate that.
I've got more coming in a few days.  Maybe I'll proto a good old MAX232
and trust the tolerance of the lpc2106. :)
David
2004-01-08 by Leon Heller
Sent: Wednesday, January 07, 2004 11:51 PM
> > made. I'll modify
needs 1
> > uF.
I can't really see both chips being faulty. You must have something else
wrong. Have you checked that all the capacitors are OK?
I get +6 V on pin 2 and -5.6 V on pin 6, checked on two boards. I'd expect
about +/- (2 x 3.3 V)
less a diode drop or two as the charge pump circuit inside the chip is
essentially a voltage doubler on the output of an oscillator.
Leon
Leon Heller, G1HSM
Email: aqzf13@...
