Lpc2000
Has any one faced optmization problem using gnu arm gcc
2005-01-20 by vijayasarathy T
     Iam using GNU arm gcc compiler for LPC2104 , when i use
     while( !( SCB_PLLSTAT & PLL_LOCK ) );)
      this statement, the assembly codes are not generated for other
instruction      below this statement. do any one have a suggestion.
thanks
T.vijayasarathy
Re: [lpc2000] Has any one faced optmization problem using gnu arm gcc
2005-01-20 by capiman@t-online.de
Perhaps because one bracket is too much (2 open brackets, 3 closing
brackets) ?
Remove the one after ";" ?
        Martin
To: <lpc2000@yahoogroups.com>
Sent: Thursday, January 20, 2005 8:18 AM
Subject: [lpc2000] Has any one faced optmization problem using gnu arm gcc
> Hi,
> thanks
> T.vijayasarathy
Re: Has any one faced optmization problem using gnu arm gcc
2005-01-20 by Karl Olsen
--- In lpc2000@yahoogroups.com, vijayasarathy T <tvsarathy@g...>
wrote:
> Hi,
Probably (SCB_PLLSTAT & PLL_LOCK) is always false, so the while loop
is infinite.  Code after an infinite loop would never be executed, so
GCC optimizes it away.
Karl Olsen
2005-01-20 by Rick Collins
> wrote:
> > Hi,
That would be my bet.  I expect that SCB_PLLSTAT and PLL_LOCK are
constants, intended to select a bit from a status word.  Just ANDing
them together produces a zero which is never true.  The OP needs to
read the status word and use these constants to select the bits for
the while condition.
